wd2 starting trouble
haveing trouble starting the wd on the handl.have to use another enging with a belt to get her going.turn it with handl got a nice spark on plug & points.but when it comes to starting it on handlt dont want to know but runs well ones its started by bump start.any ideas wot could be wrong.& i dont know why my post is half way down the dam page.
Diddy- Life Member
Re: wd2 starting trouble
Whats the compression like???
blackvanman- Life Member
seems to be good.but then thay all seem low to me.compared to the lister d
Diddy- Life Member
helping hand bump
Diddy- Life Member
Dave, a good mag should not normally Spark from the points, this could be signs of the condenser needing replacement.
When you hand crank it over a few times does the plug get wet?
gets wet the fires then goes dry.but i give up.this has beat me.lol
Diddy- Life Member
dave , dont be beaten mate , if i had more time i would say drop it off over hear and i will have a look .Diddy wrote:gets wet the fires then goes dry.but i give up.this has beat me.lol
you say the plug gets wet and then runs a bit then stops and then no more fuel getting to the plug rght ?
Just out of interest is the magneto impulse working as it should? You should hear a clunk clunk when you turn the engine over slowly by hand.
» Petter A1 Trouble Starting
» marval trouble
» Blackstone No Trouble
» Inlet Valve Trouble
» Early Lister D trouble.
» marval trouble
