Blackstone No Trouble
+4
rubythursday
callum12
8 posters
Page 1 of 3 1, 2, 3  Next
Blackstone No Trouble Empty Blackstone No Trouble
Post by rubythursday Wed Oct 09 2013, 22:20
The time has come the walrus said to talk of many things: of engines, oil and sealing gaskets.
Blackstone No Trouble Black1
The engine before work commences.
Blackstone No Trouble Black2
The crankcase door removed, it's quite clean inside
Blackstone No Trouble Black3
Barrel nuts loosened ready for a lift off.
Blackstone No Trouble Black4
Cleaning the combined oil and fuel pump reveals a previous repair - it looks as though a fixing bolt was loose and it has worn the hole, a piece of copper tube has been soldered in place to bring the hole back to size.
Tony Simons
York
www.tonysimons.me.uk
1913 Hornsby L Type 8HP, 1926 Blackstone 5HP, 1927 Lister D 'Shafty', 1940 Stuart Turner P5LY generating set, 1944 Ruston Hornsby 6PB, 1945 Wolseley WD2, 1946 Norman SC, 1971 Rover 2000 auto, 1990 VW T4 camper, 2002 Land Rover Discovery TD5 Auto, 2005 Volvo S60 auto.
rubythursday
rubythursday
http://www.tonysimons.me.uk
Blackstone No Trouble Empty Re: Blackstone No Trouble
Post by Lewis MacRae Wed Oct 09 2013, 22:31
Looking good are you going to just leave it as it is?
Post by rubythursday Thu Oct 10 2013, 17:48
I'm going to have to paint it as if you look at the other side of the head it has been welded and levelled with filler. Plus most of the top half doesn't have paint having being stripped by the previous owner. I'm going to lift the barrel as it has been stood for 30 years and I need to check the rings aren't stuck.
Tony Simons
York
rubythursday
rubythursday
Post by rubythursday Fri Oct 11 2013, 17:52
Off with its head!
Blackstone No Trouble Black5
Piston and bore look fine
Blackstone No Trouble Black6
Wire nails used as split pins on the big end!!
Blackstone No Trouble Black7
Tony Simons
York
rubythursday
rubythursday
Post by rubythursday Sat Oct 12 2013, 17:30
Today's progress - Valves refaced and seats recut. Not much to play with as the valves are nearly pocketing.
Blackstone No Trouble Black8
Coat of primer on the barrel
Blackstone No Trouble Black9
First flywheel is off
Blackstone No Trouble Black10
Both flywheels off
Blackstone No Trouble Black11
Tony Simons
York
rubythursday
rubythursday
Post by Appletop Sat Oct 12 2013, 17:56
Getting there Tony, good to see someone else uses Screwfix paint!
Post by Lewis MacRae Sat Oct 12 2013, 17:57
What colour is the blackstone going to be
Post by rubythursday Sat Oct 12 2013, 19:03
Blackstone green
It came with 2 litres.
I like screwfix primer it flats nicely.
Tony Simons
York
rubythursday
rubythursday
Post by matt86 Sat Oct 12 2013, 19:07
rubythursday wrote:Blackstone green
may have to invest in some myself , do you know if they do grey ?
Post by Appletop Sat Oct 12 2013, 19:08
Er....think the name is[color=#cc3333][b] [u]RED[/u][/b][/color] oxide.....
Post by matt86 Sat Oct 12 2013, 19:10
Villiers wrote:Er....think the name is RED oxide.....
Rob i bloody know what colour red oxide is .... il go look for myself then ...
Post by Appletop Sat Oct 12 2013, 19:11
lol! lol! lol! lol!
Post by Appletop Sat Oct 12 2013, 19:14
http://lmgtfy.com/?q=red+oxide
Or
http://lmgtfy.com/?q=grey+oxide
Post by matt86 Sat Oct 12 2013, 19:14
http://www.screwfix.com/search.do?fh_search=primer&fh_view_size=20
Post by Appletop Sat Oct 12 2013, 19:15
[quote="matt86"]http://www.screwfix.com/search.do?fh_search=primer&fh_view_size=20[/quote]
So that's a no then.
Post by matt86 Sat Oct 12 2013, 19:16
Villiers wrote:
matt86 wrote:http://www.screwfix.com/search.do?fh_search=primer&fh_view_size=20
no but do white ....
Post by Appletop Sat Oct 12 2013, 19:22
White is no good, if you get a chip it really shows up.
And as for the fish.....
Post by matt86 Sat Oct 12 2013, 19:24
Villiers wrote:White is no good, if you get a chip it really shows up.
il stick with red but though dark green on red would make it darker ??
Post by Appletop Sat Oct 12 2013, 19:25
Not really that much Matt, and for what we are doing it's fine.
I always maintain 2 coats of red oxide, 2 undercoat and 2 top coat, in reality it's 2 of red oxide, then sod it, 2 top coats!
Post by matt86 Sat Oct 12 2013, 19:30
Villiers wrote:Not really that much Matt, and for what we are doing it's fine.
sounds like me .... im tempted to make a start on the fairbanks with all this painting going around and get the block done 1st before the bad weather sets in and take 3 weeks to dry !
ps look at the reviews on red oxide
a chap called biomed says about he used on stationary engines .... name rings a bell
http://www.screwfix.com/p/no-nonsense-oxide-primer-red-750ml/48712#rating_link_anchor
Post by Appletop Sat Oct 12 2013, 20:07
[quote="matt86"][quote="Villiers"]Not really that much Matt, and for what we are doing it's fine.
I always maintain 2 coats of red oxide, 2 undercoat and 2 top coat, in reality it's 2 of red oxide, then sod it, 2 top coats![/quote]sounds like me .... im tempted to make a start on the fairbanks with all this painting going around and get the block done 1st before the bad weather sets in and take 3 weeks to dry !
http://www.screwfix.com/p/no-nonsense-oxide-primer-red-750ml/48712#rating_link_anchor[/quote]
So there is!
As for painting in winter, never had a problem as long as the air is dry, if it's damp then gloss paint goes "milky", primer is a porouse paint anyway so that isn't a problem.
Post by rubythursday Sat Oct 12 2013, 20:19
I have used the grey in the past, it is just as good. I used the red under the Hornsby Maroon, would have probably used grey if I had had any!
Tony Simons
York
rubythursday
rubythursday
Post by callum12 Sun Oct 13 2013, 18:31
nice engine, do you know how much it weighs, must be about 1/2 a ton!!
looking forward to seeing it fully restored.Very Happy Very Happy
callum12
callum12
Post by rubythursday Sun Oct 13 2013, 19:13
I think the engine is about 380kg but the trolley and wheels are heavy so I would think your guess of 1/2 ton isn't far away. I can just lift a flywheel, mind I do have a bad back, hence the chain block to take the flywheel off.
Tony Simons
York
rubythursday
rubythursday
Post by rubythursday Mon Oct 14 2013, 20:16
The crank, it should polish up ok. I have put a micrometer on it and it is ok.
Blackstone No Trouble Black12
What's up Guv?
Blackstone No Trouble Black13
Tony Simons
York
rubythursday
rubythursday
