Lister LR1
Lister LR1
I have just started work on this Lister LR1 which some one has lathered in paint.
Most of it internally is in good condition due to NO water in the oil.
But some parts are not so good.
The fuel pump is seized and the Injector doesn't look too good either.
All the Bearings are sound with the exception of the big end which has worn down to the copper.
So I have a few questions:
Where it the best place for replacement parts?
My crank bearing diameters are as follows:
Main timing side. 2.215"
Main drive side. 2.217"
Big End. 2.089"
Are these dimensions within tolerance?
Many thanks in advance.
Spen
Big End. 2.089"
Spen
Spen60- Posts : 3
Re: Lister LR1
I have the following figures from my May 1978 Lister Diesels Technical Handbook. I hope that these figures are some help.
Standard Crankshaft Journal diameter 2.2485”/2.248”
Min. Permissible worn diameter 2.245”
Bearing shell length. 1.755”/1.745”
Standard crankpin diameter 2.125”/2.1245”
Min possible worn diameter 2.1215”
Standard cylinder bore 3.001”/3.000”
Maximum possible worn diameter 3.007”
Piston diameter At bottom of skirt , across thrust face (Skirt is turned oval). 2.9947”/2.9937”
Min possible worn diameter 2.9907”
* Standard fire ring gap 0.012”/0.019”
Maximum permissible gap due to wear 0.030”
* Standard Compression & scraper ring gaps 0.008”/0.009”
Maximum. permissible gap due to wear 0.025”
* Measured in new cylinder bore
Undersize bearings available for main and big ends 0.010”, 0.020”, 0.040”
Oversize pistons available 0.010”, 0.020”, 0.040”
Crankshaft end float 0.005”/0.009”
Maximum. Permissible end thrust (lbf) 100
These are the only relevant figures in the book although it does show the metric equivalent but I didn't include them as you are obviously working in thous.
Sorry this reply is a bit late in the day, I only just noticed your post. Not much on the forums about LRs (Mores the pity)
Alan
Alan
AnotherBigAl- Born to be wild
Re: Lister LR1
ive just restored a tr2 diesel the bigger brother to yours
and got all new seals ,gaskets ,shims, fuel pump,filters and injectors from
here
http://www.stationaryengineparts.com/Lister-SR-Engine-Spares/
do a little digging around on there and/or call them on number listed
and if you have a part number list for yours ,you will be able to cross ref other engine model parts to yours as i did
o found it was all on there site for the one i did and thats a far less common and desirable engine of the times than the sr1 sr2 sr3 ect ect
if you take the heads off ,please buy the topset/ headgasket as shimes not gasket fitted and they always seam to be weapy when head is removed,even if the engine was running before hand
hope this helps kev
here
hope this helps kev
Re: Lister LR1
Thanks guys, much appreciated
Spen60- Posts : 3
» My first Lister D
» lister b help
» My first Lister D
» lister b help
