Oldest known petter av1 in presevation
Hello peoples. I was just wondering if anyone knows the oldest petter av1 series 1 in presevation ive got one which is serial number 600006 and was just wondering if there was any earlyer than mine in presevation
Mattjones- Born to be wild
Re: Oldest known petter av1 in presevation
Your best bet is to contact Jim Perkins, he will be able to shed some light on when your engine was made and possibly who it was supplied to. Have a look here > http://www.petterengines.co.uk/contact.html Hope this helps Dan
sounds a good find
hope it turns out to be the case
Thankyou biggusdanuss will contact him the engines been in the family since 1951i think and it use to run a dynamo and later on moved onto a corn crusher but it was lucky it suvived the scrap as we had a cs and a hornsby ackeroid (probably not correct spelling) but was very exited when I read the serial number plate
oldest av1
Hello
I have a series one AV1 ser no 604044 which jim Perkins dated as 1949 ,so I would think yours maybe even earlier
reiver- I really need to post more
I think they started making the av1 1946 I think , ive just started to strip the head off to see why its not starting do you have any trouble getting yours started reiver
Rebuild starting after many months sitting in the shed a big thankyou to mr jim Perkins for sorting me out spares with luck she might fire up first time reground the valves so should have better compression fingers crossed
Engine rebuilt with new parts and head gasket better compression and fuel getting up to the injector but still wont put in to life theres smoke on compression but not firing woyld there be anything else to check matt
The Series 1 was a bit of a bandit to get started from what ive heard, hope you have luck with it,
