Petter A1- Oil leak
Petter A1- Oil leak
I have now got my Petter A1 to run and have solved the stuck float problem that I had previously. But now I have found out that there is a major leak coming out from behind the flywheel. What would be the problem?
Ally's_Engines- Born to be wild
Re: Petter A1- Oil leak
There is a rubber lip seal there to seal the crank bearing, they harden with age, whip the flywheel off and you can then dig it out. Should be able to obtain one from a bearing supplier.
[quote="Foden"]There is a rubber lip seal there to seal the crank bearing, they harden with age, whip the flywheel off and you can then dig it out. Should be able to obtain one from a bearing supplier.
Pete.[/quote]
What he said...
Or it could be over full with oil or the return from that seal could be blocked, whatever it is it's flywheel off time. Get a good drift and clean the shaft well.
Pete.[/quote]
What he said...
Foden wrote:There is a rubber lip seal there to seal the crank bearing, they harden with age, whip the flywheel off and you can then dig it out. Should be able to obtain one from a bearing supplier.
He's right though, its just the whipping off of the flywheel made I laugh
blackvanman- Life Member
OK thanks lads that's helped
» Petter M Victory fuel leak
» Villiers D270 oil leak
» Leak in lister D water jacket
» Lister D now running - but small fuel leak!
» Lister D fuel tank leak - Shell detergent petrol.....
