Lister D now running - but small fuel leak!
After a year's work my Lister D is now reassembled, repainted and running. She sits nicely on her new trolley that I made as well. She fired first time which was great!
Only thing is there's a small drip from the fuel pipe where it enters underneath the float chamber. I have removed the fuel pipe and carefully rubbed down the tapered olives but the seal is still not complete. I have also carefully used wire wool gently inside the unions.
PTFE tape is not ideal for such things so I am wondering if I should just buy a new pipe or if anyone of you good people had any other suggestions.
Many thanks as always.
Re: Lister D now running - but small fuel leak!
I've used PTFE around olives and its worked well, just dont use a lot of it.
Imperial tube and olives readily available online - Green Spark Plug, Holden Vintage and Classic for example
Woodsman wrote:Imperial tube and olives readily available online - Green Spark Plug, Holden Vintage and Classic for example
Thank you so much, really helpful.
May I ask.....what about this...
https://www.stationaryengineparts.com/Lister-D-Copper-Fuel-Pipe-tank-to-carb.html
Very expensive collect the parts and make your own.
For instance Holden have two nuts, two olives and one metre of pipe for slightly less than your suggestion and you have more pipe for your next engine.
ditto maryalice.
If you're not fussed about authenticity you could get nipples with hose tails and use braided hose
Woodsman wrote:ditto maryalice.
Late production D's used braided hose.
Good afternoon. I think I am going to go down this route. OD of the existing connectors is 1/4inch. I am thinking this is the correct item but have no experience in this area and would welcome some advice from the more experienced. Thank you.
This what I am thinking of:
https://www.gsparkplug.com/1x-solder-nipple-copper-petrol-fuel-pipe-1-4-x-1-4.html
This is my pipe end:
AJC,
thats the right olive, it doesnt help if you dont know but pipe threads are not the size you require its the hole in the fitting that matters, your olive will fit on a 1/4 OD pipe and the nut will have a 1/4" hole but the thread inside the nut is larger, order a 1/4" olive with a matching 1/4" BSP nut.
Hope this helps.
Hope this helps.
» Lister D fuel tank leak - Shell detergent petrol.....
» Petter M Victory fuel leak
» Leak in lister D water jacket
» Small flywheel for Lister D
» Lister D Starting and Running, the Cuts Out!
