Villiers MK12 governor adjustment
Hello,
I have been using my "Farmer's Boy" rotary hoe fitted with a Villiers MK12 for a few weeks now. There seems to be no user manual, or information about adjusting the governor spring. The problem is when I am "hoeing" the engine wants to stall unless I help it along by lifting the handle.
Is this normal for a 60 year rotary hoe? Or does the carb need a little work? I have put the governor spring into different holes on the brass arm to see if this affects the engine torque to little affect.
What can I adjust to get more grunt when the dirt gets deep?
Cheers, Gareth
Cheers, Gareth
Mr Blackstock- I really need to post more
» which RPM Villiers Mk15?
» villiers C12 valve adjustment
» Villiers MK12, MK12/2 & C12
» Villiers Mk12 H/S
» Villiers Mk12 restoration
» Villiers Mk12 H/S
