1938 Lister D Reverse rotation
I got this Lister D the other day, supplied new to Winget Ltd Rochester Kent and was owned by D Morris Evercreech Somerset who I got the D
and pumps from one is a Blake pump as big as the D and a lister 1 1/2 pump they will be another topic.
The D was completely seized and the coil was shot, I have used one from a spare wipac I had on my A1,I have spent a little time getting it free also I have had it running,
pretty good compression too considering the valve seats were well pitted and no blue smoke either, have cleaned up head and fitted a new exhaust valve for now.
I am also thinking, as it has a lot of paint showing will only do an oily rag restoration.
Gases should flow a lot better now.
Now not sure what to do about bore as I said it had good compression, have asked this question in another post.
Re: 1938 Lister D Reverse rotation
Well I bit the bullet and went for a clean up of bore and piston and pleased with the result now its back together and running sweet if I so so myself.
» Lister D 1938 Reverse rotation my contribution to a oily rag restoration
» Lister 'D' 1936 Spec 18 Reverse Rotation
» 1938 petter a.
» Benco vacuumpump overhauling update 03072015 dating the pump. Yes it's very old!
» 1938 Lister 23D2H pump set
» 1938 petter a.
