jap 2 a flywheel
jap 2 a flywheel Empty jap 2 a flywheel
Post by kev Sat Mar 21 2015, 23:50
Hi all can anyone give me an idea on how to remove a flywheel from a jap 2 a. The shaft with the flywheel mounted ends in the rope starter pully in the centre of which is what looks like a very large screw head with slot around 6 mm wide. This ( screw head) refuses to budge even with as much heat as I dare put in. Could it be a left hand thread or am I barking up the wrong tree.
jap 2 a flywheel Empty Re: jap 2 a flywheel
Post by Polybus Thu Mar 26 2015, 09:06
G'day Kev,
I'm doing a restoration on a J.A.P. 2a as well and mine had a nut where yours has the 6mm screw head.
I can tell you my nut came off in the regular direction - ie: anticlockwise to loosen.
You might be interested in watching this YouTube video - the part that should interest you starts at about 4 minutes 30 seconds.
https://www.youtube.com/watch?v=dUlLk8bgkeY
Let us know how you go....
Polybus
Polybus
Post by kev Thu Mar 26 2015, 18:09
Hi poly bus you are correct it is normal rotation I've got it loose now many thanks for your help.
