Lister D - number on flywheel?
I know nothing!
But I now have two Ds!
I have read that the number of each engine is also stamped on the flywheel, this being the case please can someone in the know kindly advise me as to whereabouts I am likely to find it?
I have turned the flywheels till I am blue in the face!
I want to do a double check on the plate numbering.
Thank you.
Ken
Thank you.
Ken
kennill- I really need to post more
Re: Lister D - number on flywheel?
If it does have a number stamped on the flywheel it's normally on the face. Not all do tho.
Hi Ken, I know this sounds daft but mine was not visible until I cleaned the outside of the fly wheel. I had removed the paint and wire brushed but did not become visible until it was introduced to an oil stone......
Steve
Steve
slew53- Posts : 4
Thanks. I will continue the search!
Ken
Ken
» lister d flywheel
» Lister d flywheel D714
» Lister D flywheel
» What model of Lister is this, and where might I find a serial number?
» Lister D Flywheel Removal
» Lister D flywheel
