Norman t300 dating
Norman t300 dating
Just checked on the list and they are all 4 digit numbers, the governor plate on mine is stamped with 5 numbers TE 11427 and underneath is 427/810. Any ideas anyone. cheers Mark
Mark [You must be registered and logged in to see this image.] yes I can be a touch grumpy
Sparkieb- Expert
Re: Norman t300 dating
What list?
No word from Phillip Gallimore?
On mine the TE serial number is stamped into one of the crankcase feet
No reply from Mr Gallimore. The stamping is on the governor plate, havent looked anywhere else to be honest. Cheers Mark
Sparkieb- Expert
Hi Mark,
Phillip is The Norman Man, he is very good and knowledgeable about engines and especially Normans - I believe that he has the factory records on these.As a consequence he is in much demand,be patient - he will reply with as much information on your engine as he has.In the mean time good luck with the restoration.
All the best,
Kev.
All the best,
Kev.
Thankyou
Sparkieb- Expert
Woodsman i found an engine numbers list with dates online. But all were 4 digit numbers which really confused me as mine has 5, been searching so much i cant remember where it was
Sparkieb- Expert
Sparkieb wrote:The stamping is on the governor plate, haven't looked anywhere else to be honest. Cheers Mark
Hi Mark,
Can you post a photo ? Mine has a number on the governor plate but it's a ALCO reference not Norman.
Sparkieb- Expert
This was under magneto[You must be registered and logged in to see this image.]
Sparkieb- Expert
Ok how do i send just one picture ?
Sparkieb- Expert
Sparkieb wrote:Ok how do i send just one picture ?
You've got me there
Not had that problem before. Did you host and then insert or copy link from Svrimage gallery?
That little arrow mark indicates military issue I believe so other numbers may be stores location.
It comes up with 3 different listing of picture and a box that says send all. Tried touching one on acreen to see if it highlighted it but nope
Sparkieb- Expert
First dialogue is to upload image(s) to Srvimg server.
The second dialogue is to place a link, thumbnail or image in the post editor. I usually select image but others use thumbnails.
Hope that helps.
PS I find it useful to log in to the Srvimg server and create some categories to save images - makes them easy to find later.
You can also copy links from images there and paste them into the editor
Hope that helps.
Will give it a go later
Sparkieb- Expert
Which bits the post editor . Yes i know im not good at this
Sparkieb- Expert
this is also stamped under magneto
Sparkieb- Expert
Sparkieb wrote:Which bits the post editor . Yes i know im not good at this
You are in the editor whenever you are typing. You can go to Srvimg, click on a picture and it will show links click on a link a copy/paste into your post. BTW If you Edit the post you can delete the repeated urls.
I guess the stuff cast or stamped into the engine will be either Norman part number or foundry mould numbers.
