Norman T300
Page 1 of 3 1, 2, 3  Next
Norman T300 Empty Norman T300
Post by SteveNurse1969 Sun Dec 03 2023, 13:55
Work on the Norman has startedNorman T300 Img_1715
SteveNurse1969
Norman T300 Empty Re: Norman T300
Post by blue cat Wed Dec 06 2023, 18:50
Should be fun if you have the missing parts.
It's a Norman T300 Mk2, built between 1945 and 1967.
If you would like an accurate date please advise the serial number of your engine.
cat
blue cat  cat
Post by SteveNurse1969 Wed Dec 06 2023, 19:11
Serial number is TA5385 most of it is there just stripped down for cleaning and painting only a couple of bits to sort
SteveNurse1969
Post by SteveNurse1969 Wed Dec 06 2023, 20:10
Norman T300 Img_1611
SteveNurse1969
Post by blue cat Thu Dec 07 2023, 18:39
Norman T300 Mk2 supplied to Thomas Green & Sons Ltd of Leeds on 19th November 1951. It should have a Wico Series A impulse magneto fitted. Thomas Green built these engines into their Greens "Master" range of lawnmowers in the 24-36 inch cutter size. They were industrial machines used for tennis courts, cricket fields, football pitches and council parks. These mowers are really quite rare now, but many engines used in them still exist. The Greens engine is a good version to have as usually fitted with a useful twin vee pulley.
blue cat  cat
Post by SteveNurse1969 Thu Dec 07 2023, 19:22
Thanks for the information blue cat, I did suspect it was from a mower the amount of grass I found when stripping it down, it is Wico magneto trying to make a good one out of two as the one on it was a mess broken cap and bolts I will post some pictures tomorrow
SteveNurse1969
Post by SteveNurse1969 Thu Dec 07 2023, 21:03
Norman T300 Img_1612
SteveNurse1969
Post by SteveNurse1969 Sat Dec 09 2023, 17:25
Norman T300 Img_1719
Magneto rebuilt even sparks hope to put it back on the engine tomorrow and see if anything happens, afraid it won’t let me post the video of it working but I will keep trying
SteveNurse1969
Post by Woodsman Sun Dec 10 2023, 10:25
Hi Steve,
Servimg only hosts images.
You would need to try Ubend, Daily Motion or some such. I've used Streamable in the past. You can post for free but the videos disappear after ninety days I you don't open an account.
No big deal for me - I can barely remember what I did ninety minutes ago!
Post by SteveNurse1969 Mon Dec 11 2023, 19:04
Back together and now one side is apart again discovered a broken valve spring, probably explains low compression on one side, other side seems great though it may also need a valve spring looking at It, Sorry not a great picture Norman T300 Img_1724
SteveNurse1969
Post by blue cat Mon Dec 11 2023, 19:07
Good progress you're making.
blue cat  cat
Post by SteveNurse1969 Mon Dec 11 2023, 19:11
Anyone any pictures of impulse unit on Wico series A magneto trying to work out what goes where, got loads of bits I thought I had it but something is not quite righteously
SteveNurse1969
Post by SteveNurse1969 Mon Dec 11 2023, 19:16
blue cat wrote:Good progress you're making.
It’s coming on it’s good fun I was hoping to test fire it in a couple of days but I think it being apart on one side again might stop that, I think I have hopefully found a spring I can modify to work
SteveNurse1969
Post by SteveNurse1969 Mon Dec 11 2023, 20:36
That didn’t work out either impulse unit not happy still at least I got it to spark
SteveNurse1969 wrote:Norman T300 Img_1719
SteveNurse1969
Post by Woodsman Tue Dec 12 2023, 10:37
SteveNurse1969 wrote:Anyone any pictures of impulse unit on Wico series A magneto trying to work out what goes where, got loads of bits I thought I had it but something is not quite righteously
Have Parts / Service manual. PM me if you would like a copy.
Post by SteveNurse1969 Tue Dec 12 2023, 22:33
Valve spring sorted good compression now other side a bit worse than I thought looks like a bent valve, time to get the big hammer out Norman T300 Img_1727
SteveNurse1969
Post by SteveNurse1969 Thu Dec 14 2023, 19:50
Parts list is growing, could do with valve guide and exhaust valve and top piston ring, I shouldn’t have looked and just hoped all was OK but me being me I had to take it apart and check
SteveNurse1969
Post by SteveNurse1969 Thu Dec 14 2023, 19:59
And to make matters worse now I have cleaned it looks like a small crack in the rear of the casing better get the epoxy out that should sort It
SteveNurse1969
Post by SteveNurse1969 Thu Dec 14 2023, 20:03
SteveNurse1969 wrote:And to make matters worse now I have cleaned it looks like a small crack in the rear of the casing better get the epoxy out that should sort It
That probably explains why there was so much old oil on the case
SteveNurse1969
Post by blue cat Sat Dec 16 2023, 17:12
SteveNurse1969 wrote:Parts list is growing, could do with valve guide and exhaust valve and top piston ring, I shouldn’t have looked and just hoped all was OK but me being me I had to take it apart and check
I can supply a new old-stock valve guide for £8 including postage.
Piston rings you should be able to get from Cox and Turner
blue cat  cat
Post by blue cat Sat Dec 16 2023, 17:13
Where exactly is this crack ? Photo would help....
blue cat  cat
Post by SteveNurse1969 Sun Dec 17 2023, 18:32
L
I will get a picture tomorrow I am sure some epoxy will seal it, I think the broken valve guide may be a bigger problem, by any chance does anyone know of on I can make fit?
SteveNurse1969
Post by SteveNurse1969 Sun Dec 17 2023, 18:47
SteveNurse1969 wrote:L
And it was my own fault, a bit heavy handed trying to put valve spring back on
SteveNurse1969
Post by SteveNurse1969 Sun Dec 17 2023, 19:00
I would certainly be interested in a couple valve guides, one as a spare in case I get over enthusiastic again
SteveNurse1969
Post by SteveNurse1969 Mon Dec 18 2023, 08:50
Norman T300 Img_1728
Picture of the crack in the rear casing
SteveNurse1969
