Taper lock pulley
Taper lock pulley
Hi Guys,
I am looking for an 8" v belt pulley to fit a 5/8" shaft without a key way( for my Millers Falls power saw).One supplier could supply this size but with a taper lock bush,I have never used these before.
My question is - would this grip the drive shaft tight enough to drive my power saw or would it tend to spin on the shaft?
Any help or advice would be appreciated.Thanks.
Kev.
Kev.
Re: Taper lock pulley
Hi Locknut,
I have had them on electric motors and once they were tightened up they did not shift just make sure that everything is clean and no burrs.
Regards,
Chiefy.
Regards,
Chiefy.
chiefy- A credit to the forum
Never used them myself but I thought they still used a key. I'll defer to Chiefy's greater knowledge.
Thanks for the replies.
Paul,like you I thought that that they only worked with a key - hence my question - and indeed the pictures that I have seen all show keyways.
Chiefy - its good to know that they will just tighten up on the shaft alright - I had visions of getting it all set up and after a short period of time the pulley starting to slip on the shaft.
All the best,
Kev.
All the best,
Kev.
Hi Locknut,
As i said yesterday just make sure that everthing is clean and no burrs or other lumps and bumps the ones i used were tightened with a allen key in fact i thank i still have one or two in the workshop that have been put in a safe place the only problem is i cant remember where the safe place is!!!.
Regards,
Chiefy.
Regards,
Chiefy.
Hi Chiefy,
Thanks for the reassurance - I will go ahead with that in the New Year - dont want anything getting lost in the Christmas post!
I know exactly what you mean about safe places!
All the best,
Kev.
All the best,
Kev.
» Lister D taper pins and pushrods
» Lister D governor taper pin sizes
» Lister D air valve spring lock-nut
» V-pulley's
» V Belt pulley
» V-pulley's
» V Belt pulley
