lister D water hopper cover bolt size
I need to replace one bolt. size and description please. Thanks. Lister D type Water/crank case top cover bolt.
Pete- Posts : 3
Re: lister D water hopper cover bolt size
Can't help with spec as I have never owned a Lister D but doubtless someone can help.
Presumably you have others to compare? I suggest you invest in an imperial thread gauge set and a cheap digital caliper (often to be found in your local German discount store) - will always be useful.
Search the web for BSW and BSF thread tables or PM me with email address and I'll happily send what I have.
Post some pictures in New Projects/Restorations section when you can. Good luck
Either 1/4 or 5/16 Whit
» Lister D Bolt Size
» Lister D Radiator and Fan conversion
» Bolt Diameter Size
» Lister D Bolt sizes
» Lister D bolt sizes
