Lister D Bolt sizes
Lister D Bolt sizes Empty Lister D Bolt sizes
Post by wortha184 Fri Aug 12, 2011 12:57 am
Does anyone know what size nut and bolt sizes need for a 1930'ish shaft drive. Some of the original ones are missing and the others are damaged. As I am not an engineer I was hoping someone could give me a list.
Thank you, Stephen
wortha184
I really need to post more
Lister D Bolt sizes Empty Re: Lister D Bolt sizes
Post by Guest Fri Aug 12, 2011 7:40 am
Hello,
I think the Tread size is BSW (British Standard Whitworth), not sure on size, might be worth buying a pair of vernier callipers and measuring whats there.
Lister D Bolt sizes Empty Lister D bolt sizes
Post by bencam43 Fri Aug 12, 2011 8:41 am
Hi there, the bolts and nuts are 1/4", & 5/16" whitworth and cyl head nuts are 7/16" whitworth.
cheers Bill
bencam43
bencam43
Post by Guest Fri Aug 12, 2011 10:31 am
Stephen, have you tried looking on ebay as you can get them from there, also you sometimes get the odd seller that's stripped an engine and sells of the parts including the nuts and bolts but not many strip and sell the parts from the early shaftys as there worth more as a runner.
Post by wortha184 Tue Aug 16, 2011 1:27 am
Thanks for the help.
It may sound obvious but if for exampe a 5/16 BSW spanner fits a nut then that is the size of nut I need to buy a 5/16 BSW?
wortha184
Post by hob Tue Aug 16, 2011 7:07 am
in spanner size 5/16 BSW is the same as 3/8 BSF which is 0.600 AF (across flats)
see chart here
http://www.timebus.co.uk/rlh/whitworth.htm
the difference between BSW and BSF is the number of threads per inch so
BSW is 5/16 18
BSF is 5/16 22 and 3/8 20
see charts here
http://www.britishfasteners.com/threads/bsw.html
http://www.britishfasteners.com/threads/bsf.html
bencam43 says they are BSW and i have no reason to doubt that so if nuts and bolts are 0.600.across flats they should be 5/16 BSW
hope this helps
Post by BRASSO Wed Aug 17, 2011 10:39 am
wortha184 wrote:Does anyone know what size nut and bolt sizes need for a 1930'ish shaft drive. Some of the original ones are missing and the others are damaged. As I am not an engineer I was hoping someone could give me a list.
Thank you, Stephen
Hi Stephen, what ones are you after?
I think the bulk of the ones on a lister D are mainly 5/16 BSW. I have few of these in a tin. Send me a message of what you are after and I will see what I can do for you.
Martin. (BRASSO)
Post by bencam43 Thu Aug 18, 2011 5:47 pm
Stephen, all the nuts and bolts you will need for your "D" are WHITWORTH The spanner sizes that you will need are 3/16" whit spanner to fit a 1/4"WHIT BOLT & NUT 1/4" whit spanner to fit a 5/16" WHIT BOLT & NUT and a 5/16" whit spanner to fit a 3/8" WHIT BOLT & NUT,
the cyl head nuts are 7/16 whit and you will require a 3/8" WHITWORTH SOCKET FOR THOSE.! ! ! !
Bill.
bencam43
bencam43
