Climax No.1
Climax No.1
Having recently acquired a Climax No.1 pump I'm trying to find out a bit more about them. Googling the name produces lots of hits for Coventry Climax, but I can't find anything like No.1 when digging into Coventry Climax products so assume it was made by someone else who used the "Climax" as a brand name?.
Re: Climax No.1
Have a look here:
https://www.gracesguide.co.uk/Main_Page
Should be able to find something, unfortunately info on driven equipment is thin on the ground....
Re: Climax No.1
Climax pumps is always a bit dodgy when doing a google search.....
Re: Climax No.1
Villiers wrote:Climax pumps is always a bit dodgy when doing a google search.....
Ditto "Dating"
Re: Climax No.1
a bit more info here:
http://www.stationaryengine.org/climaxpump.htm
Re: Climax No.1
[quote="Woodsman"][quote="Villiers"]Climax pumps is always a bit dodgy when doing a google search..... [/quote]
Ditto "Dating" [/quote]
I am now a single man so thanks for the tip!
Re: Climax No.1
I used cork on my Goulds pump, similar set up.
Re: Climax No.1
Villiers wrote:I used cork on my Goulds pump, similar set up.
I've ordered a piece of 1.5mm rubber sheet from the bay, if that doesn't work I'll try cork next, thanks.
Re: Climax No.1
Silicone it when you put it together, I know it's a bodge but it works.
» Climax 745 parts help
» Coventry Climax Number 2 pump
» Climax No 1 pump help
» climax paint ...
» CLIMAX No 1 PUMP
» climax paint ...
» CLIMAX No 1 PUMP
