Climax No 1 pump help
+2
kevjankie
6 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Hi all, i have had this pump for a couple of years now and only just striped it all down but i think the leather cup washers will want replacing, any idea where i can get some, also i had to carefully grind the 2 nuts off to remove the cup washers, should they be brass ? because these where steel and a right pain to remove. sorry but i dont know how to add photos.
Thanks kevjankie..
Thanks kevjankie..
kevjankie- Born to be wild
Re: Climax No 1 pump help
https://i.servimg.com/u/f36/19/49/73/45/dsc02214.jpg
Thanks for the help woodsman , i will post a photo of the pump now in bits..
https://i.servimg.com/u/f36/19/49/73/45/climax11.jpg
https://i.servimg.com/u/f36/19/49/73/45/dsc02217.jpg
https://i.servimg.com/u/f36/19/49/73/45/dsc02218.jpg
Have a re-read. You can, if you wish, insert the actual picture/thumbnail rather than the url.kevjankie wrote:Thanks for the help woodsman , i will post a photo of the pump now in bits..
A nice looking pump. I have a lister H2 waiting to be put back together, lister domestic, and a Godwin A1E as well..
Yes, The lister domestic and godwin have been at both, I am not far from stratford on avon.
What is the bore diameter?
Have you tried any/all of these?
https://worldofwashers.com/shop-2/page/3/
https://fettlebox.co.uk/pump-leathers.html
http://www.cheshireleather.com/leather-seals.html
https://www.vintagepumps.co.uk/page22.html
Last edited by Woodsman on Fri Feb 18 2022, 14:34; edited 1 time in total (Reason for editing : typo)
Hi Paul,
The bore is 2x1/2", center hole is 5/8", I will see how i get on making them if i fail i will look into the sites you put up.
Regards kevin..
Regards kevin..
Make a former but soak in a softening oil first whose name I cant remember some other brainy richard will know
I have always used these for cup washers, good service and not bad price-wise. https://www.base-camp.co.uk/Cups%20.htm
maryalice wrote:Make a former but soak in a softening oil first whose name I cant remember some other brainy richard will know
Neatsfoot oil?
That's it>
Excellent job!
you still need to soak them otherwise the water will eventually rot the leather.
Page 1 of 2 • 1, 2
» CLIMAX No 1 PUMP
» Climax No.3 water pump
» Climax domestic pump ...
» help with climax domestic pump
» Climax No1 Water pump
Page 1 of 2
