List posts
List posts
Been dipping in occasionally but seem to be missing stuff. Is there any way to list all posts in reverse order of appearance to make it easy to see what has appeared without having to go through each sub forum?
NHH
NHH
nickh- Expert
Re: List posts
Portal page has scrolling list of recent posts.
Re: List posts
Thanks, both 'sort of' do the job. Sure I'll get used to the format after a bit.
nickh- Expert
Re: List posts
nickh wrote:Thanks, both 'sort of' do the job. Sure I'll get used to the format after a bit.
Hi Nick,
I guess you mean like Fozzers, where most recent posts were at the bottom of the home page. I've no doubt it's possible to hand code something but I was never a web developer so I'm loath to start tinkering and maybe break something. I'll have a butchers on Forumotion Support and see if there is an easy fix, but cannot promise.
[Edit] Just had a look on support forum and found someone asking exactly that question, with a screen shot looking like the Fozzers layout. Sadly the reply was - not possible with Forum defaults and would need to be hand coded. I'm not up to that. It would also mean that if Forumotion made any changes it might break any bespoke code. Sorry.
Last edited by Woodsman on Sat May 04 2019, 14:46; edited 2 times in total (Reason for editing : Add info)
Re: List posts
Yep, that is the sort of thing I was thinking of - always my first port of call on Fozzers.
NHH
NHH
nickh- Expert
Re: List posts
Make the most of what youv'e got Nick.
Re: List posts
Stumbled across this by accident - new addition to mobile version. But apparently no plans for implementation in web version.
https://ukengineforum.forumotion.com/latest
Maybe just change your bookmark, if you prefer?
Will look into incorporating in Home page
