Villiers Mk12
+3
chiefy
7 posters
Villiers Mk12
I've made a start on my £10 ex Monro Tiller Villiers MK12.
Looks like the original coil judging by the paint that's blown through the hole in the backplate. Interestingly the HT contact was covered in paint, I'm surprised it had ever made contact. With that cleaned up, the points cleaned and gaped and a replacement HT lead and new plug I now have a spark.
The brass carb elbow should come up nicely.
Re: Villiers Mk12
A working original Villiers coil !!
You don't find many of those.
Re: Villiers Mk12
Funnily enough, the coil on my MK15 was good too.
Re: Villiers Mk12
You are lucky i have never found a villiers that has been stood a while with a working coil.
Chiefy.
Chiefy.
chiefy- A credit to the forum
Re: Villiers Mk12
We need a "like" button coming along nicely.
You will have to try a photo in daylight to show the colour shade.
Re: Villiers Mk12
[quote="chiefy"]You are lucky i have never found a villiers that has been stood a while with a working coil.
Chiefy.[/quote]
Haven't looked very hard, I've had several Villiersssssss over the years and NEVER had a duff coil
Chiefy.[/quote]
Re: Villiers Mk12
Robotstar5 wrote:We need a "like" button coming along nicely....
Wot 'e sed
Re: Villiers Mk12
chiefy wrote:You are lucky i have never found a villiers that has been stood a while with a working coil.
Chiefy.
Me neither! I have a box of duff Villiers coils, some did spark (and reasonably well) but there was no continuity through them so wouldn't have lasted long in use. Then again many of my other engines have had duff Lucas, BTH and Wico mags as well so not exclusively a Villiers issue! They all have a certain age about them after all. I have a BTH that will need rewinding etc this winter, there may be more yet!!
Re: Villiers Mk12
"Like" Emoticon added - best I could do
Re: Villiers Mk12
I haven't seen one with the oil filler on a cast extension of the sump before.
Re: Villiers Mk12
Robotstar5 wrote:I haven't seen one with the oil filler on a cast extension of the sump before.
I think it is because it was fitted to a cultivator, so the drain plug was clear of the machine. With the sump not having the usual 'feet' I need to come up with a way of mounting it on a trolley.
Re: Villiers Mk12
A bit late, but I've just remembered that I have a some MK12 bits in the shed. Any interest in a sump with feet if it's there?
Re: Villiers Mk12
Woodsman wrote:A bit late, but I've just remembered that I have a some MK12 bits in the shed. Any interest in a sump with feet if it's there?
I *think* I am going to make a plate that bolts on to the engine behind the pulley, where it would have been mounted on the cultivator. If it doesn't work out I will bear your kind offer in mind. I have a C12 sump, but that has the oil pick up trough cast in so I don't know if it's suitable? I would like to use the original sump if possible as it is a bit different.
Re: Villiers Mk12
I find the mini hose clips look better than Jubilee type clips on fuel pipes.
https://www.ebay.co.uk/itm/11-13mm-10-PCS-MINI-HOSE-CLIPS-CLAMPS-FUEL-PIPE-PETROL-DIESEL-HOSE-ZINC-PLATED/162247747939?
Re: Villiers Mk12
All back together, looking a bit smarter...
I made a temporary base to run it, it actually started first pull, but died when I bought the revs up and wouldn't restart. I thought it was flooding so I took the carb off and found the problem..
...the piece of foam I had put in the bellmouth as an air filter had been sucked into the carb. . By then it was getting dark and starting to rain so I'll try it again another day. I also discovered that despite what I had been led to believe, silver Hammerite is not heat resistant...
Re: Villiers Mk12
blue cat wrote:I use "wood burning stove" black paint for exhausts.
The exhaust had traces of silver paint on it so I decided to it silver again. TBH it was a quick job and the Hammerite must has been 20+ years old... I've now stripped it off and redone it, managed to get 2 coats out of the last gasp of an aerosol of VHT silver that was lurking on the shelf.
Re: Villiers Mk12
Nice job - well done.
» Villiers MK12, MK12/2 & C12
» Villiers Mk12/Mk10
» Villiers mk12 ?
» Villiers Mk12/2HS
» Age of Villiers Mk12 Engine
» Villiers mk12 ?
» Villiers Mk12/2HS
