Norman T300 MK2
Norman T300 MK2
Have decided to break this T300 I have, as said earlier in a topic asking about freeing a seized piston after approx. a months soaking in all sorts of fluids and giving it a knock every few days it still stays seized and as something else has just arrived in my garage I need the space its using to work on new item.
Like others I just cannot sus out putting photos on here so engine photos if you want to look at them are on that f/ache site, [you reading this Stuart? help again if you would like to please], all I have is in photos but left cylinder is now removed, bore is plus 30 according to piston top markings. both compression rings are good and free in their groves but oil ring is stuck but not broken on left piston looking from start handle side, have not tested magneto for spark, there is one broken valve spring, engine can be turned over with spanner on flywheel nut but it moves cylinder from studs whilst doing this due to seizure.
Message me please with any questions, can post smaller items at cost but if you would like the complete lump it will have to be collect only.
This is in my way now, so all you see in photos except for the parts mentioned as spoken for is here to be collected for £30
PLEASE NOTE, magneto and carburettor/air filter elbow are all spoken for.
donp- A credit to the forum
reply
Stuart, once again I am in your debt thank you.
Re: Norman T300 MK2
workyticket wrote:Stuart, once again I am in your debt thank you.
No worries mate.
Norman T300 MK2
Right I am sick and tired of moving this around so its here for FREE TO COLLECT, took some bits of it today so can be seen as to what can be salvaged, flywheel good, valves ok , two broken valve guides valve springs weak one broken, pistons +30 cyl. bores ok, timing chest cover off so you can see inside, gov. housing off so gov. weights can be seen, NO cyl. heads am keeping those.. message me please, might get to Crakehall in January depending on circumstances at home at the time as have more important things to contend with at the moment
no longer here, gone to scrap collector
Re: Norman T300 MK2
Do you still have the magneto ? Kai from Norway
Pistonfinger- I really need to post more
Re: Norman T300 MK2
Pistonfinger wrote:Do you still have the magneto ? Kai from Norway
Sorry no, it does say it was spoken for in the thread.
Re: Norman T300 MK2
Shame, I wish I was doing mine in 2019 could maybe have sorted the carburettor I am short of
SteveNurse1969- Born to be wild
