ruston & hornsbt pb6 timing
Hi, I am trying to do the timing on my ruston Hornsby pb6 1 1/2 to 2hp. I have another which has timing marks on the fly wheel as in a line and the word spark but this one has no marks on the fly wheel! has anyone any suggestions please for timing it up. many thanks.
MICK 0196- Born to be wild
Re: ruston & hornsbt pb6 timing
Take spark plug out, insert screwdriver in the hole, turn engine over in correct direction until the screwdriver is pushed out, at this point it is at TDC so mark flywheel with chalk or a marker pen, turn back 2 inches and set points to open at that point.
pb6 timing
thanks for that Villiers, I will try that and let you know the result.
Check valves to make sure it is on the compression stroke and not exhaust stroke. You can normally feel the compression but worth making sure both valves are shut. Not trying to teach anyone to suck eggs but I do know of a certain person who did set the timing to the exhaust and then had trouble getting it to run.
Bill
BBRAP- I really need to post more
[quote="BBRAP"]Check valves to make sure it is on the compression stroke and not exhaust stroke. You can normally feel the compression but worth making sure both valves are shut. Not trying to teach anyone to suck eggs but I do know of a certain person who did set the timing to the exhaust and then had trouble getting it to run.[/quote]
Agree to a point but as the 6PB runs the mag at crankshaft speed it shouldn't make any difference as it has a wasted spark on the exhaust stroke.
Villiers wrote:BBRAP wrote:Check valves to make sure it is on the compression stroke and not exhaust stroke. You can normally feel the compression but worth making sure both valves are shut. Not trying to teach anyone to suck eggs but I do know of a certain person who did set the timing to the exhaust and then had trouble getting it to run.
You live and learn. Good to know that
Bill
Yup, quite a few of these old engines run the mag at crankshaft speed so have a wasted spark. It all depends on the engine.
BTW, what part of Gods own Suffolk are you in BBRAP?
Hi Villiers,
Thurston near Bury St Edmunds,
P.S. One of my sons lives near you, Roydon nr Diss
Bill
Thurston is a nice village, nice and handy to Bury. Yes Roydon isn't that far from me.
Thurston, that brings back memories, my Father in Law came from there and and two of my wife's aunts lived there, I'm a Bury boy ish, my parents moved us up from South London when I was thirteen along with my brother and sister. We now live in Bedfordshire.
» Hard to start Ruston PT
» wolseley timing
» Ruston PT Impulse mag timing
» mk 10 timing
» jap 2a timing and other questions
» wolseley timing
» mk 10 timing
