Allen Scythe with Villiers Engine
Can anyone confirm that the engine is a Villiers Mk VIIIc or were there other Villiers with an Alloy Cowl? Also does anyone know where I could find a date for the scythe (serial 12109). It's in a state but cheap. A good winter project to go with the Parker concrete mixer once my health improves.[You must be registered and logged in to see this image.]
Last edited by solsteam on Thu Nov 21 2019, 16:08; edited 1 time in total (Reason for editing : Serial number was incorrect)
Jon
solsteam- Born to be wild
Re: Allen Scythe with Villiers Engine
Jon
Have been doing some surfing. Have found out that it's probably a Mk. 11. Does that sound about right?
Jon
have you had a look here [You must be registered and logged in to see this link.] sometimes takes some digging, but a lot of info on there.
Thank you Paul. Just pulled it in today and it really needs help. Should be a good place to source parts. Haven't checked the engine yet.
Jon
This evening I have been told that it is a 1943 Allen type T scythe with Villiers Mk.11 engine. Just in case anybody has the same problem.
Jon
» Help With Villiers Engine
» Allen Oxford scythe.
» Villiers engine ID
