Alternator disassembly
+3
mattblack
maryalice
Robotstar5
7 posters
I hate it when manuals give an instruction without any explanation. This is what I am looking at:
"The generator is a totally enclosed, permanent magnet inductor alternator.
The rotor MUST NOT BE REMOVED FROM THE STATOR UNDER ANY CIRCUMSTANCES"
So the obvious question: why?
I can see this dividing into "you will beak it" or "it is impossible to reinstall".
Anyone know the likely answer?
Re: Alternator disassembly
If it's anything like the permanent magnet servo motors I've worked on, the magnets are that strong they will pull the rotor into the stator possibly causing damage. The correct way is using a purpose designed frame that holds the rotor shaft central to the stator/body as it is withdrawn or inserted, not something you find in many sheds
I did wonder, but this is 1945 - so not the latest exotic-material magnets.
Exotic magnets have been around for many many years their only main difference is size.
Martin P
Martin P
I may be barking up the wrong tree, but could it be that the magnets will lose their magnetism without the rotor in place? Just thinking how a horseshoe magnet should have a 'keep' on it to stop it losing it's magnetism.
Alternater When and if you strip it put it in plastic bag or cover it up they/t pick up every but of swarf or filing that you have
M0GXB wrote:I hate it when manuals give an instruction without any explanation. This is what I am looking at:
The simple answer is that if you take it out without a keeper it will lose a great deal of its magnetism. I discovered this the hard way as a teenager when I dismantled a Sturmey Archer Dynohub to clean and lubricate it. When I re-assembled it I couldn't get more than a feeble glow out of the lights.
George
George
georgineer- Born to be wild
Oh that is interesting. I had always assumed that the "keeper" effect was a long-term thing, so it would gradually fade away over months (due to thermal cycling) rather than seconds - especially since magnets with keepers were meant to be used by taking the keeper off, of course.
If you remove the magnet you will demagnetise it. we have similar problems on the stone turbo generators as fitted to south African steam locomotives. you have to remagnetise the rotor before refitting.
Gaudin98- Expert
» Lister H4 Pump Disassembly
» Villiers V type carburettor disassembly
» Car 12 volt alternator cable size
» Using car alternators
» Alternator on Petter A1
