Solex Carburettor
Solex Carburettor
Has any one got a Solex BFHD 26 Carburettor that is surplus to requirements. Mine is looking decidedly worn and weary.
Dave
HolbornDave- Born to be wild
Re: Solex Carburettor
What is this for ?, as I'm not familiar with a Solex BFHD26. Unless of course you mean a 26FHD ?
What is wrong with your carb ?
A lot of these carbs are getting worse for wear as many are 50+ or more years old and weren't designed to last that long. There are spares around and even old carbs on eBay, but both might be just as worn as your carb.
Is this the same as fitted to Bamfords, EV & EG engines, if so I had a long wait for the one I bought of ebay, that was a few years ago now too.
OK, done a bit of research on this. The Solex 26 BFHD is a vehicle carburettor for 1920/1930 Citroen/Peugeot cars. No idea if they were used on stationary engines. Would seem to be quite hard to find and therefore a little expensive when they do turn up. There is currently a 26 BFHL version in eBay for +£300 !!! and a float chamber with float for +£70, but these might be opportunistic sellers prices. Could be like hens teeth
SOLEX Carb
blue cat wrote:What is this for ?, as I'm not familiar with a Solex BFHD26. Unless of course you mean a 26FHD ?
It's off a Moteur Ceres engine I've just bought. The BF is the type, HD means its a vertical carb and 26 is the inlet aperture size in mm. Dates from 1931. It's working ok but the body has suffered a lot from corrosion
Dave
Solex Carb
chrismac wrote:Is this the same as fitted to Bamfords, EV & EG engines, if so I had a long wait for the one I bought of ebay, that was a few years ago now too.
Not sure if they fitted them to those engines Chris, but I'm not expecting any to turn up in a hurry
Dave
Solex Carb
blue cat wrote:OK, done a bit of research on this. The Solex 26 BFHD is a vehicle carburettor for 1920/1930 Citroen/Peugeot cars. No idea if they were used on stationary engines. Would seem to be quite hard to find and therefore a little expensive when they do turn up. There is currently a 26 BFHL version in eBay for +£300 !!! and a float chamber with float for +£70, but these might be opportunistic sellers prices. Could be like hens teeth
You may well be right. I have managed to turn up a manual for the BF and FF types on the WWW it's all in French but thankfully had a translation facility and was able to print off FOC. The translation is far from perfect but the diagrams are legible so it's possible to work things out OK. The carb seems to functioning OK so not in a desperate hurry to replace the body, but thought I'd put some feelers out. Thanks for taking the trouble to research
Dave
» SOLEX FH Carburettor #
» Solex 26 FH Carburettor
» Solex 26MV carburettor
» SOLEX FH Carburettor information
» Solex 26fv carburettor banjo
