Solex 26 FH Carburettor
Hi all looking for Solex 26 FH Carburettor for a Bamford EG1 or some internal parts Please
Re: Solex 26 FH Carburettor
https://www.ebay.co.uk/itm/SOLEX-carburettor-came-of-a-running-engine-but-not-used-for-a-wile/133017047826?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Thanks blue cat
no problem, I recently had a carb from this seller and it was near perfect.
Just in case you missed the last one..
https://www.ebay.co.uk/itm/401791456727
While this is indeed a Solex 26FH carburettor, it will not fit a Bamford EV/EG engine as per OPs request.
blue cat wrote:While this is indeed a Solex 26FH carburettor, it will not fit a Bamford EV/EG engine as per OPs request.
Thanks for that. Would you care to elaborate for the benefit of less knowledgeable members, i.e.me?
The Solex 26FH carburettor comes in both left and right handed versions. So the float bowl can be either on the left hand side or the right hand side. The Bamford EV1/EG1 uses the version with the float bowl on the left hand side (type 26FHG where G=gauche, French for left)) otherwise the float bowl will foul the exhaust outlet on the engine.
On the other hand the Fowler 1PAL uses the version with the float bowl on the right (type 26FHD where d=Droit, French for right). The Solex 26FHD carb version will not fit the Bamford.
The left and right handed versions are not interchangeable, hence my original comment above.
Here you can see the difference, 26FHG on the left, 26FHD on the right:
The float bowl, throttle tube and choke arrangements will fit both models, it is only the centre part that is handed.
In addition, the throttle tube (the piece with the flange) can be rotated to 4 different positions giving great versatility in governor linkage positions.
Great - many thanks
Thanks guys it/s the one on the left 26FHG is the one I need or the internal bits jets etc Please
» SOLEX FH Carburettor #
» Solex Carburettor
» SOLEX FH Carburettor information
» Solex 26MV carburettor
» Solex 26FV carburettor problems for a Petter AS 3BHP
» Solex Carburettor
