Villiers c12
Villiers c12
Hi All
What's the jet sizes for the Villiers c12 it's got the b10/1 carberettor.
Because mine runs very fast with no throttle. No leaks no flooding.
No idea what it came off. It's got parallel shaft. I am assuming it's
the pilot jet with long tube it's stamped 35. Main jet 34.
Many Thanks
Andrew
Many Thanks
Andrew
Re: Villiers c12
Might be of use. Looks like it has the smallest jet installed.
https://www.winget.co.uk/document/VILLIERS%20C12%20OPS%20MANUAL%20ELECTRONIC%20IGNITION.pdf
Re: Villiers c12
Cheers Stuartturnersteve
Looks like pilot jet is the smallest. When it's back together i will look into it further.
Many Thanks
Andrew
Many Thanks
Andrew
Re: Villiers c12
Spares here.
https://www.lsengineers.co.uk/villiers-carb-spares.html
Re: Villiers c12
Didn't know they existed. Your a star thank you.
Many Thanks
Andrew
Many Thanks
Andrew
Re: Villiers c12
Hi All
The pi!ot jet with the tube does it have to have the tube
part to run because I have am idea to make it run slower.
Andrew
Andrew
» Villiers F15
» Villiers Mk 20 and Villiers Mk 40 HS
» villiers 12/2 hs
» engine number 4 of the VILLIERS WX11 PROJECTS
» Job lot of Villiers !!
» villiers 12/2 hs
