Lister D exhaust pipe
+2
maryalice
6 posters
Good afternoon.
I have removed the exhaust assembly. Pipe and baffler have come off the engine flange cleanly but are corroded together - no amount of penetrating oil is going to free it.
Stationary engine spares have long been out of stock for exhaust pipes although they have bafflers.
I am going to try and source an exhaust pipe but need to check this out with those of you have more experience in this area.
My thinking:
1 inch diameter pipe with a BSP tapered thread both ends.
Am I correct? If so is the BSP tapered thread a standard size please?
Thank you.
My thinking:
Thank you.
Re: Lister D exhaust pipe
either tapered or parallel, which ever you have, measure the pipe inside diameter not the outside as pipe is measured by the bore.
As maryalice says nominal size is based on the inside diameter, measured in inches, of a steel pipe for which the thread was intended. So a 1/2" BSP thread actually measures more like 3/4" with a ruler.
Plenty of info online. If you haven't already, also get thread tables for BSW, BSF, BSC etc.
The reason pipes are measured on the internal diameter is for calculating flow rates through them in design.
Eric
Eric
cranium- Expert
Your average Plumber is unlikely to hold steel pipe for that size try your local BSS Branch and ask for offcuts as you dont want 20 feet
eBay works.
https://www.ebay.co.uk/itm/3-4-BSP-MALLEABLE-iron-pipe-fittings-INDUSTRIAL-STEAM-PUNK/254612552627?hash=item3b48173bb3:g:vOwAAOSwIzpe0p-G
I'm pretty sure this will do the job and has the correct thread. Please would one of you kind people take a moment to check it out and let me know please?
Thank you.
https://www.bes.co.uk/extended-nipple-mild-steel-12-x-1-black-9805/
Thank you.
a foot of pipe might be a tad long.
StuartTurnerSteve wrote:a foot of pipe might be a tad long.
Thank you. I agree about a foot being a little too long. But is the size and thread correct?
I think Lister D are 1" BSP, it's been nearly 30 years since I've owned one......
I should think about 6" to long
tony RA wrote:StuartTurnerSteve wrote:a foot of pipe might be a tad long.
https://pipeworksuppliers.co.uk/index.php?route=product/product&path=80&product_id=248
I've used these guys a few times.
Thanks for all the advice - I have learned a great deal about BSP and BSPT threads.
However, I've just realised I've been dim! The Lister D silencer on Stationary engine parts has a six inch pipe attached -the perfect length. It was right under my nose. Sorry for wasting everyone's time but, as I said, I have learned a great deal so I thank you again.
Your questions are not a waste of time. Anything that promotes discussion, disseminates knowledge and shares experience and expertise is valuable.
Keep posting
Keep posting
The BES pipe would have saved you a few pennies.
Woodsman wrote:Your questions are not a waste of time. Anything that promotes discussion, disseminates knowledge and shares experience and expertise is valuable.
Keep posting
Thank you for the encouragement, I appreciate it very much.
» building a exhaust pipe
» Ruston 6AP Exhaust Pipe + Oilers
» Correct fittings size for fuel pipe Lister A
» Exhaust flange bolts Lister D
» Lister d exhaust
» Lister d exhaust
