Petter A1 engine stop.
Hi all. My Petter A1 runs very well but the only way I can stop the engine is to turn off the fuel and wait until it stops. Is there a way to wire up a kill switch to the spark plug or anything else?????
Greenwizard334- Born to be wild
Re: Petter A1 engine stop.
What magneto is on it? There is usually a button to earth out the magneto.
Not sure but I can't see anything. I'll try to have another look tomorrow and see if I can make out what mag it is.
Mag is either a Lucas SR1, Wico A Or Wipac CJ normally, the SR1 has a bakerlite or pressed steel end, the Wico a bakerlite cap on top and the CJ is all ali, unless it is a ministry spec then it could have a different top.
Just seen a photo of your engine, it is the Wipac CJ. If I remember right there is a brass button on the end cap you can press...
Hi all. I have run the engine but the stop button isn't working........ so I'll have to keep letting it run out of fuel to stop it????
Adjust the throttle so when you push the arm right in it stops.
Good idea. Thanks, I'll try that.
You could also do it Villiers style - small brass strip to short out HT terminal on spark plug.
Yes. Ive got something like that on my old briggs and stratton rotavator.
» Petter PA2 engine
» Petter A1 engine
» PETTER OIL ENGINE
» Petter PA1, no engine no
» Petter PA2 engine
» Petter A1 engine
» PETTER OIL ENGINE
