Giving Stuart an overhall
This pump came with a Lister D we picked up a couple of months ago. Lister is chugging away just fine, but pump not doing anything.
So we took it apart to find out how it works, and eventually extracted the leather (more like concrete) cup washers and chucked the in some old engine oil for a few days to soften up.
Meanwhile made templates for the pump chamber gaskets and cut them out of nitrile-cork using a laser cutter at work (school DT department!).
bodisham- Born to be wild
Re: Giving Stuart an overhall
Well done! They are a nice pump and a little different with the "window"
'... laser cutter' - some folks have it easy.
Woodsman wrote:'... laser cutter' - some folks have it easy.
I like to mix old tech with the new! ;-)
Very good!
I was thinking the same, I have to make do with ball pein hammer and some of my grandfather's well used gasket punches he had from Upex garage before WW2... so they are a bit blunt!
'... laser cutter' - some folks have it easy. Wink
Just think of the time he wasted loading all of the parameters in for the different gaskets he made, 5-10 mins loading data for each gasket, upto 30 mins for the lot, maybe longer as one offs, ball pein hammer done in minutes
[quote="maryalice"]Just think of the time he wasted loading all of the parameters in for the different gaskets he made, 5-10 mins loading data for each gasket, upto 30 mins for the lot, maybe longer as one offs, ball pein hammer done in minutes
Maryalice[/quote]
Doing well if you can "cut" cork sheet with a ballpein hammer, whenever I try it doesn't work.
Maryalice[/quote]
Appletop wrote:maryalice wrote:Just think of the time he wasted loading all of the parameters in for the different gaskets he made, 5-10 mins loading data for each gasket, upto 30 mins for the lot, maybe longer as one offs, ball pein hammer done in minutes
Not wishing to be picky the new gaskets are not cork and re your attempts, your hammer is not big enough
[quote="maryalice"][quote="Appletop"][quote="maryalice"]Just think of the time he wasted loading all of the parameters in for the different gaskets he made, 5-10 mins loading data for each gasket, upto 30 mins for the lot, maybe longer as one offs, ball pein hammer done in minutes
Maryalice[/quote]
Doing well if you can "cut" cork sheet with a ballpein hammer, whenever I try it doesn't work.[/quote]
Maryalice[/quote]
Size isn't everything dear boy....
Maryalice[/quote]
Maryalice[/quote]
» giving up rallying so lots of stuff for sale
» Stuart Turner A4
» STUART MAG
» Stuart Turner AF4
» the stuart issue
» Stuart Turner A4
» STUART MAG
» Stuart Turner AF4
» the stuart issue
