Petter Junior reassembly
In 1970 I was given a Petter Engine to rebuild, I stripped it down but never got round to putting it back togeather. Over the years it has suffered from bad storage but is mostly all there. The engine is sn 1187 1922 with magneto on the front. I really need an exploded view to show all the parts and how they go togeather.
AndyAustin- I really need to post more
Re: Petter Junior reassembly
What you have sounds like a series 1 Petter M 1 1/2hp? If so very nice, an engine that is on my "want" list! They are not very common as they weren't a commercial success.
I doubt you will find an exploded view of one and I don't think there is one of the series 2, not that it would help.
Here is one I grew up knowing.
DSCF0352 by Bryntin Photography, on Flickr
Steve thanks for the picture it is really clear and will help with checking for missing parts.
No worries, best of luck with it, if you get fed up of it send it this way
Hi Andy and welcome to the forum.
Sounds like you have a fine first project - loads of help and advice to be had here. Good luck
Please post a couple of pictures when you are able.
First question which way does the piston go? We loosly assembled the bottom end with the notched side towards the spark plug but looking at a not very clear picture we think that is wrong.
A second question is about the hole in the side of the crank bearing support into the crank case it was plugged with a grease stuffing cup. Is this to pressure the lube oil feed, ours seems to be gravity fed from a small tank.
Also we assume the felt crank seals just sit sandwiched on the outside of the bearing.
Piston goes slope to the exhaust if I remember right. if it has greased mains then it will have greased mains with a greaser in it and the oiler will drop oil into the crankcase somewhere. Put a photo up of your main bearing housing and oiler, that would help. And as far as I know the greased bearing M didn't have a felt seal.
» my petter junior 2.5hp
» Petter junior 5 hp
» Lister Junior A
» Petter Junior 5 BHP What oil for lubrication ?
» Petter Junior Patent Safety Oil Engine - aka M Type.
» Lister Junior A
