Wolsley block
Wolsley block
Hi all, when I bought my house 40+ years ago there was a WD2 in a shed with a frost burst damaged block, I have finally got round to sorting it out, it turns freely, no sticking valves and has compression, would you advise patching the block or sourcing a replacement, any advice appreciated
I removed the flywheel so I have good access to the repair area
Bandycoot- I really need to post more
Re: Wolsley block
I've repaired them in the past, just got some cast rods and welded them up, if you need a block I think I have one spare.
Re: Wolsley block
Thanks Appletop, the popped out piece is missing and I cannot weld, does it have to be cast welded to cast? I was going to to tap the block and bolt a cover over the hole with gasket, as it is not a pressurised system I thought it may work, I will post pic of hole,
Re: Wolsley block
Crikey, that's one hell of a hole!
Alan
Alan
Re: Wolsley block
I know, there is a bare block on eBay with a repair of similar size, £18 start price, I would have that but with collection only it’s a bit far for me, there is just enough at the sides to drill and tap so I will have a go, keep you posted
Re: Wolsley block
Nice engine robotstar , keep you posted
Re: Wolsley block
Go for it, what have you got to lose? (apart from your sanity)
And a proper 'shed find' engine too.
Re: Wolsley block
Dearest mattblack, my sanity went a long time ago, I would. Like to keep the engine original as possible, might even leave it scruffy, someone said on this site ‘in its working clothes’ struck a chord, watch this space
