New kid on the block !.
+2
mattblack
Cotterpin@77
6 posters
Hi there glad to join up, I have a pretty but rusty J.A.P 2a engine no 2AC 4480, It was a bit of a ebay impulse buy and I suppose it's the sort of engine size and weight where a trailer is unnecessary, hoping that with a bit of help I can get it going !.
Cotterpin@77- Born to be wild
Re: New kid on the block !.
Hello and welcome!
There's a lot to be said for smaller engines, it means you can fit more of them in any given space...
Welcome sir
Garak- Life Member
Hi and a warm welcome to the forum. I also like the little air cooled jobbies.
I look forward to seeing some pictures in New Projects/Restorations when you get started
The letter "C" in your engine number would suggest a date of 1948.
Thanks for the welcome from you all, I have got to say that tinkering with old engines is a great stress buster,best £30 I have spent in a long time !.
Looking at the carburettor which is an original J.A.P and to info that has been posted on the matter I think your right about it being a 1948, J.A.P dropped that carb as the engine would die when rocking about at excessive angles while used in a rotavators as an example.
The engine is in a stripdown mode and I will post some pic's, the exhaust valve was jammed open but has been encouraged back into operation with some WD40 and a little tlc so we now have some good compression, next job to get flywheel off.
Hi Cotterpin@77
Welcome to the forum. I am also doing a jap2a reverse rotation.
Andrew
Andrew
Hi there Andrew, hope your Jap 2a restoration is going well they are nice little engines !.
