Pump seals.
Pump seals.
Ok before I mess up am I right in thinking that new leather seals to go into a lister water pump have to be soaked in oil first. If so how long for?
im interested to know this aswell stu
Im interested to know this as well stu as i got to make some seals up for my climax
Re: Pump seals.
Neates Foot Oil is the ideal lubricant, but I just soak them for a day in a vegetable or olive oil. Whatever the wife wont miss!
Re: Pump seals.
Amos pumps recommend soaking for about a week in vegetable oil.
Makes the cups nice and supple for getting them in the pump.
Hope this helps.
Hope this helps.
BRASSO- Life Member
Re: Pump seals.
Stu I normaly leave them soaking for a week as well
Re: Pump seals.
When I was in the Airforce you had to soak the Hub seals on a Bedford MK for 24 hrs before fitting but i noticed if you left them longer they lasted longer so if you leave them for a week or so you should be ok.
Also try and soak the seals in oil that it will be lubricated with that way the oil wont try and separate due to diffrent viscosity ( blody big word for this time of night).
Re: Pump seals.
I did not now you new any big words up that end of the country
Re: Pump seals.
JONESEY wrote:I did not now you new any big words up that end of the country
Cheeky sod,
I ate a dictonary for breakfast.
» Seals for S12 carburettor
» Villiers lightweight oil seals.
» can anyone recommend a maker of seals
» Wolseley wd2 crank shaft oil seals
» Found Something For The Amanco To Run
