ananco chore boy
ananco chore boy
ive got an air cooled chore boy ive fitted new oneway valve and new fuel pipe there is a good supply of fuel and the ignitor is ok the engine runs for a short while and then stops anybody any ideas
futura9838- Born to be wild
Re: ananco chore boy
You will probably need to supply photos of the fuel line arrangement that you have before we can sensibly comment. As a new member to the forum I think you have to wait 7 days before you can do this (a forum rule).
Air lock or new valve is stuck shut, is it also fitted the correct way around.
ananco chore boy
thanks for the replys i bought the engine a couple of months ago the previous owner had the same problem it had a home made tank and a dodgy valve and a fued pipe coiled up
franks tanks lovley man sold me a new tank tap pipe and one way valve the tank wants sealing so ive rigged a pipe up with the new one way valve from the old tank loads of fuel through now the card to head joint leaks so new gasket needed for there the needles not pitted im thinking too if fuel leaks from joint it must admit air too im going to try that then its off with the head a decoke and valve lap
im not an expert just trying one thing at once i will try to put some photos up ive spent years watching these engines at shows and cannot resist the tempation to join them thanks all
ananco chore boy
does the ignitor run on a 6 or a 12 volt battery and does the ampage matter ive got a new coil
