Norton Villiers F15
+4
mattblack
Garak
Hairyloon
8 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Norton Villiers F15
I'm trying to repair a Norton Villiers F15 generator set which looks very similar to the one in this YouTube video, except that mine is missing some significant bits, and the condensor is mangled.
So my first question here is on the condensor: does anyone know the specifications for it?
Is there even much difference between one condensor and another? They all do the same job and one spark is much like another spark...
And can anyone advise on an exhaust? Mine is completely missing...
Re: Norton Villiers F15
I have a manual for Villiers F15 rather than Norton Villiers but I'm guessing parts are much the same.
Condensor - IIRC it should be 250VDC and around 2.2 microfarads
Try L&S - showing out of stock at the moment but worth a call.
https://www.lsengineers.co.uk/villiers-f15-ignition-condensor.html
As for exhaust, that (eyelid) style does pop up on fleabay now and again. L&S have 'pepperpot' style but you would need to check flange dimensions and hole centres.
Woodsman wrote:I have a manual for Villiers F15 rather than Norton Villiers but I'm guessing parts are much the same.
Thanks, I've sent them a query. Meanwhile, I have to wonder if there is any signficant difference between automotive capacitors and the ones loitering in my random electronics box...
But first I'll check the capacitance of the spare one for the van.
Any tips on search terms for ebay? I'll expect about 7 million results if I search for "Exhaust"...
Do we know how critical anything about it is? I'm inclined to assume not: it's not a racing engine: it shouldn't need to be critically tuned.
Woodsman wrote: 2.2 microfarads
0.22µF
Garak- Life Member
I used the exhaust elbow off a C12 on my MK20 so I know they are the same hole spacing, I'll compare it with the F15 on my Allam generator to see if its the same.
I used an aftermarket Briggs & Stratton silencer screwed into the Villers elbow, if you're not worried about originality a search for 'lawnmower exhaust' on ebay should come up with something you can adapt.
Couldn't find 'µ' on my keyboard !!Garak wrote:Woodsman wrote: 2.2 microfarads
0.22µF
Woodsman wrote:Couldn't find 'µ' on my keyboard !!Garak wrote:Woodsman wrote: 2.2 microfarads
0.22µF
If you are using Windows try Alt + 230 or Alt + 0181
If you are using Mac OS or Mac OSX (as I am) it's Alt + M
Garak- Life Member
0.22µF
The position of the decimal point was the rather more serious issue...
Is is 22 or 2.2µF?
0.22µF
These are different by a factor of 10 !!
Oh, and RIFA capacitors are not that reliable, they have a reputation for letting the smoke out
I don't think space is a relevant issue on this engine. At least, not in these terms. Did he give any reasons why that one? Possibly that is a question for an electronics forum...
My Mk20, MK12 and F15 all have the same exhaust flange hole spacing so you have some options.
blue cat wrote:Garak wrote:Woodsman wrote: 2.2 microfarads
0.22µF
I was taking part in a discussion on a FB magnetos group concerning repairs to a Wico magneto and this was a quote from the group moderator.
Wima caps have always had a good name. I'd want to check their DV/DT rating, but I've never knowingly had a Rifa PME271M fail yet, and always managed to physically fit them in anything.
https://www.facebook.com/groups/349645382440054 Wico EK a nice surprise
Last edited by Garak on Thu Mar 10 2022, 07:46; edited 1 time in total (Reason for editing : Rearanged text)
Garak- Life Member
Garak wrote:blue cat wrote:Garak wrote:0.22µFWoodsman wrote: 2.2 microfarads
No Greek characters and a typo!! Not mine finest post. Apologies to all
Woodsman wrote:No Greek characters and a typo!! Not mine finest post. Apologies to all
Well I don't know: what a way to greet a new member!
Seems you've been around here longer than I have !!
Ah yes... but only on paper...
Did we resolve this question?Hairyloon wrote:Woodsman wrote:Couldn't find 'µ' on my keyboard !!Garak wrote:Woodsman wrote: 2.2 microfarads
0.22µF
Is is 22 or 2.2µF?
Ignoring the small point that the suggestion was 0.22 not 22...
Either way I had no luck finding anything on an initial enquiry, and I put the project back on the shelf, but given that they're threatening us with power cuts, I thought I'd best raise its priority...
[url=Rifa PME 271 M X2 0, 22µF]Rifa PME 271 M X2 0, 22µF[/url]
Garak- Life Member
Garak wrote:[quote="Either way I had no luck finding anything on an initial enquiry, and I put the project back on the shelf, but given that they're threatening us with power cuts, I thought I'd best raise its priority...
[url=Rifa PME 271 M X2 0, 22%C2%B5F]Rifa PME271M 2.2µF capacitor on Fleabay[/url][/quote]
Thank you.
The link is broken, but searching that on ebay gives multiple hits...
The question remains on what capacitance, and also on how much does it mater?
Thank you.Hairyloon wrote:Garak wrote:[quote="Either way I had no luck finding anything on an initial enquiry, and I put the project back on the shelf, but given that they're threatening us with power cuts, I thought I'd best raise its priority...
The question remains on what capacitance, and also on how much does it mater?[/quote]
I'll try again: Fleabay Link
2.2µF is the correct value for condensers.
Garak- Life Member
Thanks. Got that on order now. Today is proving to be expensive.Garak wrote:Hairyloon wrote:Thank you.Garak wrote:Hairyloon wrote:Either way I had no luck finding anything on an initial enquiry, and I put the project back on the shelf, but given that they're threatening us with power cuts, I thought I'd best raise its priority...
A tenner is not a lot, but it seems like a lot for a little capacitor, and on top of that, I've just not quite accidentally bought two more engines...
Oh, hang on, that link is for a 0.22µF... I hope you misplaced the decimal point?Garak wrote:I'll try again: Fleabay Link
Hi I got my replacement capacitors from Brightspark Magnetos, see link below.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwizo9-M99L6AhU-QkEAHW8NAg0QjBB6BAgOEAE&url=http%3A%2F%2Fbrightsparkmagnetos.com%2Feasycap%2F&usg=AOvVaw2odMPD6fBwR-I_p7ZeW_I_
They produce the "EasyCap" which is available in two values as a universal replacement device, as well as bespoke replacement units to suit certain magnetos. They also have a good description on the function and selection of the value of capacitors for magneto use.
Neil.
Neil.
neil (LE) wrote:Hi I got my replacement capacitors from Brightspark Magnetos, see link below.
Well, I've ordered the one off ebay now. I'll see how that goes, but thank you for the suggestion.
» Norton villiers f15. Any info at all please?
» Norton Villiers DO7 Engine dating
» Norton flat aircooled twin
» Villiers c12
» Villiers c12
Page 1 of 3
