Lister d thread sizes
Hello all you engine crazy peps.
Probably been asked loads of times and a silly question but so I don't order the wrong tap and die set.
What are the nut and bolts thread sizes of a lister d ? Is it just three sizes 1/4, 5/16, 3/8 bsw.
Looking at a bsw tap and die set all the sizes I need would be in there if this correct.
Cheers Ryan.
Cheers Ryan.
Ryan90w- Expert
Re: Lister d thread sizes
Ryan,
You are correct in your assumption.
Most nuts and bolts are BSW; but some water and brass bungs, and fuel pipe fittings are BSP (as is the threaded tube for the air valve). Some magneto small threads might be BA, and the spark plug is Metric.
Forgot those
https://www.stationaryengineparts.com/lister-d-thread-size-guide/
Andywaters- Life Member
» Lister D Bolt sizes
» Lister D bolt sizes
» Lister D governor taper pin sizes
» Lister A drain tap thread help !
» Villiers Mk25 nut sizes
