Petter W1H refurb (1950)
+6
neil (LE)
mattblack
maryalice
Andywaters
10 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Petter W1H refurb (1950)
I did a long day
exhaust/manifold stripped and painted
A spare carb I already refurbished.
Started mechanically stripping the old paint
Cleaned and checked the piston/rings, I found the middle ring was binding due to a tiny dent on the edge of its groove.
Refitted the barrel and set the tappets 10 thou
Sorted the decompression lever and the magneto interface
Hopefully finish stripping tomorrow
Andywaters- Life Member
Nicely done. Don't know if to strip and paint my PB or get my mate to Cerakote it. Exhaust and carb that is.
Thanks Steve.
A short but productive day.
Almost finished stripping and priming.
After removing the crankcase access plate I checked the sump and found it to be a good half inch deep in jellied oil. So I drained all the oil that was still fluid and poured a litre of paraffin in.
A paint brush taped to a stick enabled reaching extremities and its now clean.
First coat of colour
Another good day
First coat on tank
1mm corks inside tank straps
Mostly two coats done now
First coat on tank
Full photo set
https://techno.smugmug.com/Petter-W1H/
Magneto and HT lead fitted
Drain tap cleaned up
Belt drum and fuel pipe
The last of the second coats
Lovely Andy. Sorry I can't imagine this one sitting forlornly in a farmer's field! Another restoration up to your usual high standard. Keep it up.
Cheers,
Neil.
Cheers,
Neil.
Thank you Neil
The reflection of the belt drum in the flywheel is amazing
I’m sure the paint will dull in a few weeks
At least it’s back to the original colour even if the high gloss is not original.
I’ll never be an oily rag man. Personally an engine that did its service and survived deserves the best attention for its retirement.
I’m looking forwards to showing this alongside the Lister D of same age. They really do hit it off together with 50 rpm separating the beats.
I’m making a lid for the hopper too, I glimpsed an image in an advert with one but not good enough to copy. I’m making it from an IKEA chopping board.
Rough draft
Rough draft
Ready to run tomorrow and polish the flywheel
Still needs a bit of tweaking and some tiny bubbles indicating head gasket issue. I’m assured these all leak a little but I’ve ordered a composite replacement from SEP
Nice one, looking smart.
Thank you
The hopper lid is done too. I wondered what the purpose of this might be but having tried moving the engine while the hopper has water in it becomes obvious especially when its hot water.
I thought the lid was to stand your mug on to keep your tea warm...
dunno but I’ve just seen boil in the bag sticky toffee pudding in a hoppermattblack wrote:I thought the lid was to stand your mug on to keep your tea warm...
For those steel wheels that I really hate I have ordered 3mm thick self adhesive backed rubber to make them tolerable
Tomorrow I’m beginning the refurb of the original carburettor along with scavenging the 11 carbs I bought on eBay for £77
White vinegar can be found on Amazon at under £10 for 10 litres delivered.
Well, I thought the lid was to avoid the water slopping all over the nice shiny polished flywheel rims and making nasty rust streaks! Seriously, do you treat the polished surfaces to counter corrosion, if so what do you use? I have used A.C.F. spray in the past but I just wondered what you used, if anything.
Neil.
Neil.
Scotchbrite pad when it runs, oily rag before stopping
You can't beat the traditional ways of doing things.
Neil.
Neil.
I took the hopper off today in preparation for the new head gasket.
Immediately one is struck by how much easier the W1H is to service than the A1, 7 nuts and the fuel pipe connector and you’re done.
Cast wheel upgrade
Shod in 3mm self adhesive rubber
The starting handle wasn't going to be neglected either.
I ground off an old weld on the end of the handle, drilled and tapped 6mm
Finished with an SS washer and screw
Stripped and primed with my favourite
An interesting page from the manual
Postal workers strike delaying completion
That's about it.
Well done, looks great.
Lovely job Andy.
Well done Andy, another one completed to your high standards. Would look great on any rally field or as an exhibition display model.
Neil.
Neil.
Thank you one and all
Now what’s next
Now what’s next
» Lister A (Junior) 5hp 1950 for sale
» NIJ Norman T300 1950 MK2 Project Starts
» RH B.HP6-ClassAP Refurb.
» Coborn C3 refurb.
» Coborn C3 refurb.
Page 3 of 4
