Types/brands of Paint for engines
+9
Andywaters
maryalice
neil (LE)
Garak
Robotstar5
68jcb
Matthew
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Hi all, I am new to these engines and recently acquired a Lister D, running but very rusty and paintless. I am wondering what type and brand of paint to use, any advice and guidance welcome.
Matthew- I really need to post more
Re: Types/brands of Paint for engines
Hi, Paragon paint, Mid Brunswick green, a lot of people use it. Have a look on Stationary engine parts!
Craftmaster is another good paint - https://www.craftmasterpaints.co.uk/
Craftmaster gets my vote
Garak- Life Member
Oh dear, I hear the sound of a can of worms being opened Very much down to personal preference - ditto primer.
Agree with RoBo - good results thus far.
I sometimes apply a coat of clear ethanol resistant laquer where there is a risk of petrol spillage.
Keep away from the new eco friendly water based paint, it's c**p!
Plenty on ebay, Amazon or the ones listed above that will do the job, I use Screwfix red oxide primer then a couple of coats of colour on that and it seems to be fine.
If you decide to use Craftmaster, make sure you select the engine enamel rather than the coach enamel, as it is more resilient and harder wearing than the enamel range. I have used both in my time and found them to be good products, it is also used by the railway preservation society that I volunteer at.
Neil.
Neil.
Thank you very much for all the information, I forgot to ask how to deal with the severe pitting from rust, any more information would be very welcome
Tha can allus tell a Yorkshireman, but tha can't tell him much
Matthew wrote:Thank you very much for all the information, I forgot to ask how to deal with the severe pitting from rust, any more information would be very welcome
Its part of the engines character and history, clean it, de rust it then paint it, don't use filler to hide it.
Thanks for the suggestion, I am just worried the paint will flake off but I can understand where you are coming frommaryalice wrote:Matthew wrote:Thank you very much for all the information, I forgot to ask how to deal with the severe pitting from rust, any more information would be very welcome
Not if treated properly with anti rust before you paint.
Thank you very much for this piece of wisdom!maryalice wrote:Not if treated properly with anti rust before you paint.
I've changed to this recently as Paragon has become more expensive.
I normally used Paragon for brush painting but I would not be at all surprised if these came out of the same factory.
A good smooth finish can be achieved even on sheet steel
Andywaters- Life Member
For primer I use this anti corrosion paint and buy it 6 cans at a time. It dries very fast and can be over painted in an hour in my experience
https://trade-mart.co.uk/products/action-can-rx-90-red-oxide-primer-ral-3009-500ml
Of course, the alternative is to clean off the loose rust and go over it with an oily rag...
For me even better, linseed oil it all over is another way and preserve its working life.
Newbie here - is there any concern about how hot the engine runs and whether some components (certainly the exhaust, but maybe also the block and cylinder head?) need special high temperature paint, eg VHT, or are Paragon / Craftsmaster good for high temps anyway? ? Thanks. Chris
stebbo87- I really need to post more
Only time you'd need a VHT paint is on exhausts and vaporizers any other paint is normally fine.#
Look at Granville cylinder black for exhausts & air cooled barrels etc.
This engine is hand painted with Paragon enamel
Andy, is the Paragon paint resistant to petrol splashes?
I have used barbeque/stove black aerosol to good effect on exhausts.
Alan
Alan
The longer it’s allowed to harden the more resistant it becomes but I would always have a cloth ready for spills.
Speaking in days/weeks not hours
Thanks, might try it on the next project - looks like it has some 'body' in it!
Alan
Alan
I think you will find that HMG in Manchester manufacture most of the paints listed above. They certainly make Craftmaster. There coach enamel is very good and is available at about £16.00 per ltr from the works. The other good paint available is from Manor coatings at Shiply near Bradford. I think Bromborough paints are agents for them.
Gaudin98- Expert
Hull East Yorkshire
"This paint is a heat resistant gloss enamel specifically formulated for use on: stationary engines, engine blocks, engine bays & similar.
Ideal for all restoration work on Stationary Engines, Classic Cars, Custom Cars, Military Vehicles and similar.
This product can also be used in a wide range of environments around the home, at work, in the caravan, on the boat etc.
Resistant to heat, oils, diesel, grime, stone chipping etc,
Ideal for: engine blocks, brake callipers and similar."
Page 1 of 2 • 1, 2
» Oil grades/types for old Villiers engines
» What Engine oil do you recommend for a lister "a" and "b" types
» Wico Series A magneto types
» Which UK manufactured air cooled engine brands were never ever associated with lawnmowers, motorcycles or motor vehicles?
» picture of p5X
» picture of p5X
Page 1 of 2
