How to remove calcium in Lister D water jacket
Hi All,
Just a very quick question!
Renovation going very well on two D’s, after repairing frost damage, and removed rust from water jacket, but I seem to have a very heavy deposit of calcium in one engine, that is very stubborn to remove.
Does anyone have a good remedy to dissolve calcium while engine is in bits!
Many thanks in advance
Mark
Mark
Endckr111- Born to be wild
Re: How to remove calcium in Lister D water jacket
I've never had to descale any of my Lister D's but a good descaler should do the job, are you sure its scale as the hoppers have rusty metal that breaks off and blocks the holes and channels.
I've used Kilrock when an engine is running and boiling.
Citric acid descaler from Wilko is cheap and effective, especially when warmed up - don't breath in !
Thanks guys, definitely calcium! I shall give your suggestions a try once it’s up n running
Many thanks
Mark
Many thanks
Mark
Calcium Carbonate I hope! Mixing water and calcium could be entertaining
» Leak in lister D water jacket
» Lister DK Remove Crank bearings/Shaft.
» Lister D water in sump
» Lister D water drain tap
» Lister H1 water pump in gwo
