Villiers Mk25 running speed
Completely runout of ideas. We have a Mk25 with a type 3/4 carb. Can only get it to run at tickover or just a bit faster with the throttle fully open. Tried adjusting the needle and both a 3 1/2 and 4 1/2 needle. Any ideas about getting it to run properly in a normal throttle slide range will be gratefully received. Plug is black so it must be running rich.
AdrianRJackson- I really need to post more
Re: Villiers Mk25 running speed
Governed speed set too low? Does it have a separate butterfly in the inlet linked to the governor?
Good suggestion, but it’s not running fast enough for the governor to kick in.
I suspect either carburation or ignition timing. The engine is in a museum and I only see it once a week, tried all sorts with the mixture, so next week I check the timing again. The tappets are a bit sloppy but surely that’s not it.
AdrianRJackson wrote:The tappets are a bit sloppy but surely that’s not it.
Not sure exactly what you mean by sloppy.
With both valves fully closed there should be a gap of 6 to 10 thou between tappet cap and valve stem.
Definitely check ignition timing - flywheel isn't keyed to shaft so easy for it to slip having set the contact breaker/gap.
I've had a backfire cause the timing to go off.
Thanks Paul.
Will check timing and tappets again on Tuesday when I see the engine again
Another couple of thoughts:
Is the engine physically 'tight', ie a partial seizure somewhere?
Exhaust port and/or exhaust partially blocked with carbon?
» New member. Villiers Mk25.
» EX MOD Villiers MK25 X2
» Villiers MK25?
» villiers mark 25
» Villiers MK25 Paint Job
» Villiers MK25?
» villiers mark 25
