Lister D bearing lubrication
Hi,
Can someone kindly explain how the two Lister D crankshaft bearings are lubricated? I can see oil can get between the counter weight and bearing housing to oil one bearing,but how does it travel to oil the flywheel side bearing?
I noticed in the restoration book, it states no grease is required for either bearing on reassembly, which I intend to follow, but would be interested in previous question
Many thanks
Endckr111
Many thanks
Endckr111
Endckr111- Born to be wild
Re: Lister D bearing lubrication
The bearings are lubricated by the dipper splashing the oil about lubricating everything through drillings in the con rod and onto the main bearings via the crank shaft and running through the bearing housing to the front bearing.
Yes I understand that, but if it gets past the connecting rod side bearing it drains along bearing housing,and out at cutout in bearing housing,and back to sump, completely missing out on front bearing
Eindecker
Eindecker
I've a cut away drawing in one of my Lister D manuals and it shows the lubrication flow lines, I have never had to change bearings but when I've had a D apart there is oil in the cartridge, I have faith in the manufacturer that they have got it right so don't worry about it.
As somebody who is interested in aviation I see your Nom De Plume is a first world war Fokker aircraft.
Hi,
Yes! I am an avid fan of the eindecker! Made a few r/c models in the past.
Right ok I will go along with the flow! Be very intreasted to see oil flow lines if ever you see it again!
Thanks for putting my mind at rest!
Eindecker oops Mark
Eindecker oops Mark
For those that don't know ein decker means one wing
Not many know that! Bit of history!
» Cooling fan bearing - Lister D
» Lister D air and lubrication
» Lister D main bearing rumble
» Lister D crankshaft bearing oil feed
» Lister D main Bearing
