1946 - Petter A11, Governor issue
1946 - PETTER A11, GOVERNOR ISSUE
From Swarf55 To Swarf55, Today at 14:53
Good afternoon ALL, hoping that someone out there can assist please?
I noticed the Governor pin was retracted into the hole in the casing rather than pretruding against the Governor arm.
Iv'e since taken the casing off and found the rear pin - ball bearing and a plate broken in two pieces in the bottom of the casing, the outer pin was still located in the brass outer attached to the outer case.
I assume the broken plate should look like the second photo, it appears to be peened over to hold the pin in place?
Question is, I can make a new hardened plate as the broken one and a new pin, however I can't see any such part on any exploded drawings on the forum etc, can someone assist PLEASE.
THANK YOU IN ADVANCE
See attached photo's
Swarf55
Swarf55- Posts : 3
» petter a1 carb issue
» Petter A1 governor
» Petter PAZ1 governor spring part number / supplier
» the stuart issue
» Lister D fuel tap issue
» the stuart issue
