Villier C12 & Alcon pump - strip down question
Afternoon all
Have acquired al Villiers C12/Alcon pump set complete. I am in the process of stripping the engine set down but am unsure of how the pump is seperated from the drive off the engine.
Can anyone point me in the direction of how to remove the pump?
I have attached a photo to help.
Thanks
David
Thanks
David
Dastewartd- I really need to post more
Re: Villier C12 & Alcon pump - strip down question
I'm not 100% sure but I think the engine may have an extended crankshaft with the impeller on the end, in other words you have to remove the impeller to remove the pump casing from the engine.
Thanks i did think this however the impeller has been secured to the shaft in a way that is not removable. So wanted to check first.
Have a butchers at this thread:
https://ukengineforum.forumotion.com/t9637-villiers-mk25-and-alcon-pump
PS Have manual if needed.
Woodsman wrote:Have a butchers at this thread:
Thanks i had seen this pist but that pump is totally different to the one mounted on my engine
Ooops.
Can you let us have model number and I'll see if I have any other info?
» removing alcon pump
» JAP 2S and ALCON water pump
» alcon pump set..jap engine powered.
» Villiers Mk25 and Alcon Pump
» Briggs and Stratton I/C Alcon pump.
