Norman T300
Page 2 of 3
Page 2 of 3 • 1, 2, 3
SteveNurse1969- Born to be wild
Re: Norman T300
I'll bet thats an old mould casting fault, not a crack.
Re: Norman T300
I did think that as well but not sure as the carburettor is also smashed so I suspect it had a bit of a drop at some timemaryalice wrote:I'll bet thats an old mould casting fault, not a crack.
Re: Norman T300
SteveNurse1969 wrote:[/img][/url]
Picture of the crack in the rear casing
That looks more like a casting flaw to me rather than a cracked aluminium casting. Oil is more likely to come out of joints, especially if someone has damaged the metal to metal surfaces, or out of the shaft seals if the sump is overfilled or the internal oil return holes are blocked.
Message me when you are ready for the valvel guides, I can supply the two as requested.
Re: Norman T300
SteveNurse1969 wrote:I did think that as well but not sure as the carburettor is also smashed so I suspect it had a bit of a drop at some timemaryalice wrote:I'll bet thats an old mould casting fault, not a crack.
The carburettors are made of mazak, a very weak metal, which can fall apart even if you just look at it the wrong way
Re: Norman T300
I will message tomorrow thanks for all the help and advice, ps I tested it today seems to be good compression on both sides now just to get a good spark and sort the timing
blue cat wrote:SteveNurse1969 wrote:[/img][/url]
Re: Norman T300
Hi
Sorry for the dodgy pictures it went dark on me, anyway busy day today, built a base for it, filled it with oil and tested for oil pressure which was fine messed with the magneto again for some reason spark disappears at higher RPM, finally give it some easy start and it made promising noises, I don’t think I will get it to run until carburettor is sorted
Re: Norman T300
What CC and maker is that.
Re: Norman T300
It’s 7.9kg no other informationo that is about as much as we knowmaryalice wrote:What CC and maker is that.
Re: Norman T300
I'm pretty sure this has been posted before but it's that time of year!
I went to the zoo the other day, there was only one animal in it, it was a shih tzu.
Re: Norman T300
Woodsman wrote:I'm pretty sure this has been posted before but it's that time of year!
Re: Norman T300
I managed to get a bit done on the Norman started making a starting handle for it, it did also try to run a bit and a nice backfire so I wonder if the timing is ok
Re: Norman T300
The Wico magneto should trip when the TDC mark on the flywheel is at the top.
Re: Norman T300
Rosie is getting groomed tomorrow so I ordered the cheapest carb I could find on Amazon as I am off work tomorrow let’s see if I can make it fit and maybe work, sure it will take a bit of modifying but it did try and run on easy start today
Re: Norman T300
Hello from Norway. What is missing on your spare magneto ? I do not have a magneto at all on my TA5622......
Pistonfinger- I really need to post more
Re: Norman T300
P.S. Welcome to the forum. Please post a little about yourself in New Members.
Re: Norman T300
Pistonfinger wrote:Hello from Norway. What is missing on your spare magneto ? I do not have a magneto at all on my TA5622......
TA5622 was originally sold to Arthur Lyon & Co Ltd of London on 27th August 1952. It was an export order.
Engine was originally fitted with a Wico Series A impulse magneto.
Re: Norman T300
[quote="Pistonfinger"]Hello from Norway. What is missing on your spare magneto ? I do not have a magneto at all on my TA5622......
Hello and welcome, my spare magneto has been used to fix the one on my Norman and it doesn’t quite fit for some reason it is about 5mm different in height
TA5622 plus a ALCO generator on it.
blue cat wrote:Pistonfinger wrote:Hello from Norway. What is missing on your spare magneto ? I do not have a magneto at all on my TA5622......
I think this was for the norwegian army, dark green, but it is 110 V ? Still missing the magnerto.....
Re: Norman T300
Hi Kai,
Best to start a new thread in Pride and Joy or New Projects/Restorations rather than tack onto an old thread.
Last edited by Woodsman on Fri Jan 19 2024, 14:22; edited 1 time in total (Reason for editing : typo)
Re: Norman T300
It just ran still on ether but it went, can’t get it to run on the carburettor yet bit of adjustment I think
Page 2 of 3
