Villiers V for Victory engine! Ex RAF
Hi all,
Just picked up a WW2 Air Ministry villiers engine, that is ex RAF and was attached to a convertor board that would have the health and safty fainting!
There is a desire to get it going again, i like a challange!, so far i have compression! but no spark!
Once i have worked out how to upload some photos i will let you lot have a look!
Stevegully- Posts : 4
Re: Villiers V for Victory engine! Ex RAF
Hi Steve and a warm welcome to the forum.
Tutorial here https://ukengineforum.forumotion.com/t9665-how-to-upload-images.
Did a V engine some time ago: https://ukengineforum.forumotion.com/t8942-villiers-the-v-engine
Let me know if you need a manual. Good luck.
Hello and welcome!
A few of us loonies on here like a Villiers, I'm sure we'll be able to sort you out.
I agree with mattblack, I am one of those loonies as he terms it, hence my latest purchase.
donp- A credit to the forum
IIRC Original park plug was Lodge CB.3 No doubt someone else can confirm.
Try Green Sparkplug Co for equivalent.
Admin wrote:IIRC Original park plug was Lodge CB.3 No doubt someone else can confirm.
Thank you, I will get researching tonight!!
Looks like a new HT lead is required! Have a look for for Hyperlon (I think) copper stranded and old school brass connector
If you go for a modern style plug cap then make sure there is no resistor.
The bakelite screw-in sleeve in the backplate may well be seized - plenty of Plusgas / GT87 and patience required!
Take it steady and keep posting.
Just checked spark plug - Lodge CB.3 Equiv from Green Spark plug
https://www.gsparkplug.com/1x-klg-spark-plugs-ml50-eqv-lodge-cb3-champion-7coml.html
They also have spade terminals.
First port of call should be the coil.
HT side should have a resistance of 4.5 K - there is every chance it will be open circuit!! If not, you are in luck.
LT side should be very low ohms - it will probably show as short circuit on a digital multimeter.
Make sure you slip a piece of card between the points so that the coil isn't earthed when testing.
» Villiers V Engine
» Villiers "The V Engine"
» Villiers - The V Engine.
» Villiers V Engine
