Norman T600 Carb
Norman T600 Carb
Hi Chaps!
I come to a conclusion that the carb is to blame for its poor running!
Fuel pours out everywhere not out of the bowl but the jet side and this is only when engine is off
I find it hard to explain but i think John knows there seems to be a loose joint around the jet area of carb when you attach the carb to the engine
Do you think a Zenith (Petter A1) carb fits?
Thanks
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Statman- Life Member
Re: Norman T600 Carb
What type of carb is on now like adam?
the 24T2 is used on the smaller engines, but i dont know about a T600.
HI ADAM...
don't forget its the ENSTONE SORT OUT next month...
who knows what you may find up there....
good luck in your quest to find a carb.....
regards......mike.....
» My Norman T600 MK1
» Oil for Norman T600
» Norman T600 compaired to T300
» Villiers B1o Carb
» Carb. float
» Villiers B1o Carb
» Carb. float
