Carb. float
Carb. float
Hi, I have bought a recently a 1948 Wolesley WD2 and I am having problems with the carb flooding, I have dismantled the carb and found out somebody has bodged the float, they have soldered two wires on the float to grip the valve stem but the float is slipping up the stem which is causing the problem with the flooding. Does anybody know where I can buy a new float from, I have tried the Amal web site but they don't have them for this type of Amal carb.
Thanks, Bernard.
Thanks, Bernard.
steamman- Expert
Re: Carb. float
Give us a size, and I may have one, they may even be the two wire ones, if it's the right size, usually they have a notch in the stem, no notch?
Re: Carb. float
Have a butchers at my V engine thread
https://ukengineforum.forumotion.com/t8942-villiers-the-v-engine
carb float
Hi Keith, thanks for the reply, the valve stem does have a notch in it but the wires that have been soldered on are that thin they are worse than useless, I will take the float out at the weekend and send you the sizes.Keith-PU8 wrote:Give us a size, and I may have one, they may even be the two wire ones, if it's the right size, usually they have a notch in the stem, no notch?
Thanks, Bernard.
steamman- Expert
Re: Carb. float
steamman wrote:Hi Keith, thanks for the reply, the valve stem does have a notch in it but the wires that have been soldered on are that thin they are worse than useless, the float is 1.250" dia. x 1.265" height with a .074" dia. bore.Keith-PU8 wrote:Give us a size, and I may have one, they may even be the two wire ones, if it's the right size, usually they have a notch in the stem, no notch?
Thanks, Bernard.
steamman- Expert
Re: Carb. float
Hi Bernard,
The post I mentioned above shows how to replace the wires. It's not terribly difficult.
Re: Carb. float
All the Wolseley WD's I have encountered have had the two soldered wires on the float, they are often broken at one end. Some have had several grooves in the needle to adjust the float level.
» Carb float
» Float removal
» Lister D Carb Float
» Help float and carb on lister d
» Carb Float + needle assembly
» Float removal
