Lister D Bolt sizes
Lister D Bolt sizes
Does anyone know what size nut and bolt sizes need for a 1930'ish shaft drive. Some of the original ones are missing and the others are damaged. As I am not an engineer I was hoping someone could give me a list.
Thank you, Stephen
Thank you, Stephen
wortha184- I really need to post more
Re: Lister D Bolt sizes
Hello,
I think the Tread size is BSW (British Standard Whitworth), not sure on size, might be worth buying a pair of vernier callipers and measuring whats there.
Lister D bolt sizes
Hi there, the bolts and nuts are 1/4", & 5/16" whitworth and cyl head nuts are 7/16" whitworth.
cheers Bill
cheers Bill
bencam43- A true Stationary engine owner
Stephen, have you tried looking on ebay as you can get them from there, also you sometimes get the odd seller that's stripped an engine and sells of the parts including the nuts and bolts but not many strip and sell the parts from the early shaftys as there worth more as a runner.
Thanks for the help.
It may sound obvious but if for exampe a 5/16 BSW spanner fits a nut then that is the size of nut I need to buy a 5/16 BSW?
in spanner size 5/16 BSW is the same as 3/8 BSF which is 0.600 AF (across flats)
see chart here
http://www.timebus.co.uk/rlh/whitworth.htm
the difference between BSW and BSF is the number of threads per inch so
BSW is 5/16 18
BSF is 5/16 22 and 3/8 20
see charts here
http://www.britishfasteners.com/threads/bsw.html
http://www.britishfasteners.com/threads/bsf.html
bencam43 says they are BSW and i have no reason to doubt that so if nuts and bolts are 0.600.across flats they should be 5/16 BSW
hope this helps
see chart here
BSW is 5/16 18
see charts here
hope this helps
hob- Life Member
wortha184 wrote:Does anyone know what size nut and bolt sizes need for a 1930'ish shaft drive. Some of the original ones are missing and the others are damaged. As I am not an engineer I was hoping someone could give me a list.
Thank you, Stephen
Hi Stephen, what ones are you after?
I think the bulk of the ones on a lister D are mainly 5/16 BSW. I have few of these in a tin. Send me a message of what you are after and I will see what I can do for you.
Martin. (BRASSO)
BRASSO- Life Member
Lister D bolt sizes
Stephen, all the nuts and bolts you will need for your "D" are WHITWORTH The spanner sizes that you will need are 3/16" whit spanner to fit a 1/4"WHIT BOLT & NUT 1/4" whit spanner to fit a 5/16" WHIT BOLT & NUT and a 5/16" whit spanner to fit a 3/8" WHIT BOLT & NUT,
the cyl head nuts are 7/16 whit and you will require a 3/8" WHITWORTH SOCKET FOR THOSE.! ! ! !
Bill.
Bill.
» Lister D bolt sizes
» Lister d thread sizes
» Lister D Bolt Size
» Lister D governor taper pin sizes
» lister D water hopper cover bolt size
