Lister A fuel system problems !
Page 1 of 2
Page 1 of 2 • 1, 2
firstly i have had the engine running today fro around half a hour . and notice 2 main problems .
1 , I have leaking fuel unions and tried to tighten them up but they are tight . Its the one on the fuel feed from the pump at the pump end and the carb end as well . What can i do to seal these ? Was thinking on using PTFE tape but is it petrol proof ?
the 2nd is that can a fuel pump pump too much fuel ? As mine seem to be, as much as i fiddle with the carb getting fuel dripping out of the air intake/choke plate its not peeing out but ones its going well you can see it gathering in the bottom hole .
If i was to rebuild the fuel pump / re pack the glands would this help ? The pump does weep a little bit though , how would you repack this ??? anyone who has done it before that can give me some hints ?
regards , matt
regards , matt
Re: Lister A fuel system problems !
Oh and also what size graphite string would i need to use for the packing ?
Try giving the unions a good clean ,they ieak becouse they have been over tightened. Is there not a pipe that runs back to the tank for excesse fuel
JONESEY wrote:Try giving the unions a good clean ,they ieak becouse they have been over tightened. Is there not a pipe that runs back to the tank for excesse fuel
il give the threads and unions a good clean , and Chris there is a return pipe but get fuel dripping out of the choke plate , You can alter the height of the fuel level in the carb though by lowering the return union in the bottom of the carb .
Thats what you got to do then long time since I played with a lister this was the last one
Before and after
Before and after
That is a Cracking job you have made there mate . Was that engine the one you did for ian ?
reconise it from the dent ....
regards matt
regards matt
Thats the one Matt runs like a clock
Definitely no problem with PTFE & Petrol.
Can't help with the main problem but carburetor needle valve may be letting by.
Had a similar problem with my Petter A.
Hope this helps,
Phil
Hope this helps,
Phil
Capstan- Born to be wild
Well tonight i quickly wiped off the pump pipes and tank .
I cleaned up all the mating surfaces , and threads with wire wool and the wire wheel . hopefully they should not leak when put them back together . Also stripped the pump apart and inspecting all the parts even though i have taken it apart before , well that was a few months ago .... well a mate of mine did it . I found there is no pump packing
Here are some pictures
Im assuming the pump packing winds around the piston and sits on top of the machined shoulder in the pump body itself , then the spring followed by the piston and the pump cap ....
As well i removed the needle from the carb and there was some much / rust on the tip of the needle so i cleaned that up . Just need to blow through the jet before i assemble it . hopeful all that should cure my problem . I dont think there is any point lowering the level of the return pipe . My theory is that i have never touched it and has not been touched in 40 years and probably not touched from when it was new . All the times i have had it running in the past it has not dribbled out of the carb , so i will jsut put it back together and see . Apparently you are superposed to run the engine half on choke when not on load .
Regards , matt
Regards , matt
hi there matt
when i rebuilt my lister A i replace the packing as theere was none left but bits it dripped about 4 egg cups full of fuel a day on the field
i used some***********1/8" -3/16" mine is not a constant diameter lol ********* steam engine gland graphite rope worked well all season no leaks after the first 30 secs of running after standing for a few weeks,
use plenty of good oil while slidding it back in the bore
also remove the fuel start/ run stop screw from top and screw all the way out and check the tip bottom of the needle is complete and not bent
as this couses fuel to drip out through the choker plate
if theres not the problem there
then it could be the inlet valve needs a little more play as people and me have set them back up to the book and find they are worse than before mine spitted small amounts of fuel out the carb and found that the inlet valve was opening just before top dead center and whisping the out out and sucking it back again seconds later
as i learned with mine and others have said later on to me
LISTER As AND Bs ARE A SET BY EAR AND NOT THE BOOK the book will get it going but tweeck later buy sound and you will use less down time and less fuel over the week ends
thanks kev
thanks kev
Kev you are a star mate ! I think you have cured the problem as after i rebuilt it it did not drip fuel and the valve clearances was alot bigger now i have set it to 10 thou inlet and 12 thou exhaust as i have stripped it down again for another cleaning .... and it makes sense to me .... i think its going to be one of those tricks that not many people will know as on another forum no one has even suggested that idea yet ....
the needle i have removed and cleaned its not visibility bent or miss shaped but where its been stuck in same position for 40 years is a slight dint in the needle just before the shoulder when goes parallel so not on the tip .Dont think that would effect it .
Cheers mate .
Cheers mate .
Oh kev could you measure your inlet clearance mate , would save me alot of time going by a bit at a time . I can go by what yours is set and tweek from there .
Cheers .
Cheers .
[quote="matt86_wd2"]Oh kev could you measure your inlet clearance mate , would save me alot of time going by a bit at a time . I can go by what yours is set and tweek from there .
Cheers .
Matt[/quote
matt give me ten mis to go back and dig the engine out and measure it up for you and ive put the packing diametre on above now for you
back soon as
Cheers .
Matt[/quote
back soon as
hi there matt
inlet on mine is 0.25 thou
exhurst is 0.27 thou
we all forget that these engines are near a 100 yrs old as there new to us LOL in the 60s and is classed as a fine and solid internal state by the anson engine muesum men that did a rally field parsal stripe down demo with mine
so the wear and tear has to be allowed for mine was rebuilt buy lister
so it looks like the 2 thou difference is working still lol
hope this works for you like it for me on mine
let me now how she goes after
thanks kev
thanks kev
[quote="kevjhnsn"]
At this hour mate , your a keen enthusiast
matt86_wd2 wrote:Oh kev could you measure your inlet clearance mate , would save me alot of time going by a bit at a time . I can go by what yours is set and tweek from there .
Cheers .
Matt[/quote
back soon as
i think that will solve it as is set to 10 thou .... quite alot smaller, so it is opening a bit before it should do with a smaller clearance , it would open and close quicker rather than staying open longer for the fuel to flow through . I will try this as soon as i can once i have some pump packing .
top man
top man
hi matt
if you cant find any local to you
PM your address and will send you some up to you
and get you SWINGING AGAIN LOL
thanks kev
thanks kev
Fuel cap and packing will be sent tommorw just put them in a jiffy bag so I will post them 1st class next day so you can sort it
Wow you guys did a lot of engine sorting last night hope everything works out well and all is cured and drip free
stationary stu wrote:Wow you guys did a lot of engine sorting last night hope everything works out well and all is cured and drip free
Stu you think what Kev suggested it all makes sense a,d the valve is fully open sooner only by split seconds but enough to make a difference as the clearance was alot bigger than what it is now .
regards matt
JONESEY wrote:Fuel cap and packing will be sent tommorw just put them in a jiffy bag so I will post them 1st class next day so you can sort it
Thanks Chris
be good to get it sorted and up and running so i can have a 'Christmas chug'
That sounds good you will get the nabours coming round so make sure you have some beers around
JONESEY wrote:That sounds good you will get the nabours coming round so make sure you have some beers around
Dont think i will Chris they hate me running my engines it annoys them .... but they can not do fuk all as they have complained to the council but they contacted me to see what it was about and as its a hobby and is not over the DB level they can not do anything . So i could have 30 running at same time if i wanted too .... if i had 30 engines lol *
That can be aranged come and get all mine that will piss them off, I havent got anybody to piss off round by me the only one how,s so say deaf is Roy and he,s round like a shot oil can in hand.
I am thinking about making a gate in the headge at the bottom of the garden so he dont have so far to go
I read what Kev was saying and yes it did all make sense, by the time you consider years and years of wear and not every engine is exactly the same, it's worth remembering once you get an engine running you need to fine tune to that engine not whats wrote in a book.
Page 1 of 2 • 1, 2
» lister d carb problems
» Lister D carb problems.
» Lister B fuel tank.
» Lister D - Carb Problems
» Lister D - Starting Problems
Page 1 of 2
