Lister 'd' to lister domestic pump
hi there, new to this set up,, have a lister 'd' and have a lister domestic D.E.P pump,, the pump has a 'V' belt pully and the engine a plat belt pully,, would like the pump to work on flat belt pully,, can, I replace with a flat belt pully,, what sort?, and how
fretman- Born to be wild
Re: Lister 'd' to lister domestic pump
yes you can , you need to uncrew the grub screw and remove the key and pull the pulley off but you might find it hard finding a flat belt pulley with a small bore .. You can use a SPA v belt and run it from the flat belt pullley from your engine .fretman wrote:hi there, new to this set up,, have a lister 'd' and have a lister domestic D.E.P pump,, the pump has a 'V' belt pully and the engine a plat belt pully,, would like the pump to work on flat belt pully,, can, I replace with a flat belt pully,, what sort?, and how
thanks for that,, but what is a spa v belt then that allows me to run off the flat belt pully
SPA is the v belt wedge size that will fit your pumps v pulley without being too big .fretman wrote:thanks for that,, but what is a spa v belt then that allows me to run off the flat belt pully
oh the length is calculated around the belt in mm .
thanks for that Matt will sort that out then , sounds better than replacing the pump pully
alot easier i say .fretman wrote:thanks for that Matt will sort that out then , sounds better than replacing the pump pully
have a look at this
https://www.youtube.com/watch?v=3Jy-dDQEtEo
ignore the name as its wrong but you get the idea , matt
a v belt will run on a flat belt pulley ok for rallying purposes, all my milking stuff is v belt running off a flat belt
PROPER JOB
Matth92- Life Member
Thanks for that matt,,, yes seems the way to go, have checked out the belt for this ,, sounds good.
» Lister domestic pump help ....
» Lister Domestic pump
» My lister domestic pump
